AdventureSubaru Posted June 18, 2014 Share Posted June 18, 2014 Finished up the EJ22 swap on the 99 Outback 2 days ago. It was a pick n pull motor, so a bit of a gamble, but it started right up. smoothed out pretty quick. But it's got quite the tap to it. Was worried about rod knock but the more I research, the more it sounds like collapsed HLAs. Motor is a 95 2.2 out of a legacy. Prior history unknown except it sat in the Stockton CA heat with the engine drained of oil for a while. Gave it a new timing belt and fresh oil. Took it for a drive and the engine performs fine but has that annoying tapping. I found this write up which was very helpful. http://lovehorsepower.com/joomla/index.php?option=com_content&view=article&id=43:valve-lash-adjuster-replacement&catid=10:subaru-legacy&Itemid=59 But my remaining questions are - Do the HLAs pop out or screw out? What is the torque spec for the rocker assembly bolts? Any difference between the intake/exhaust side HLAs? Any other tips or tricks from those of you who have done this before? Link to comment Share on other sites More sharing options...
idosubaru Posted June 18, 2014 Share Posted June 18, 2014 Run it. In 50 miles or less the tapping is going to go away. HLA's just need primed and air bubbles pushed out. They are LOUD after having sat for awhile, they sound ominous as you describe, "is that rod knock!?!" That being said, they're easily replaced if need by, just drop in and pull out, though some get stuck just due to time. 1 Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 18, 2014 Share Posted June 18, 2014 How long did you drive it? These can take 30-45 minutes of driving to pump up. Did you reseal the oil pump? Check the screws on the backing plate? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 18, 2014 Author Share Posted June 18, 2014 Only drove it a few miles. Following your advice, I drive it a bit more and let it idle in the driveway for a while. The sound faded and is barely noticeable now. YAY! One more thing off the list. 1 Link to comment Share on other sites More sharing options...
Olnick Posted June 18, 2014 Share Posted June 18, 2014 Congratulations, Adventure! You might want to consider throwing a small bottle of MMO (Marvel Mystery Oil!) in the crankcase. Do it for the last 100 miles or so before an oil change. I'm not a "crankcase additive" guy--but this stuff really works to clean up those small passages the oil has to squeeze through! Link to comment Share on other sites More sharing options...
