Lucky Day 99 Impreza 2.2 Timing Belt Teeth gone - It's OK
Picked up a 99 Impreza Sedan.
I could rotate the crank but the cams did not turn.
Got it home, pulled the cover and teeth on  the crank gear portion of the belt are all sheared off.
Toothed Idler Frozen solid.  New T-Belt and pulleys and it fired  up.  No valve tick that I can detect.
In pretty sad shape, needs TLC but it will be a good Subaru again!
NAPA belt, first time I have ever seen teeth sheared off a belt.
