19804wdPOS Posted June 30, 2014 Author Share Posted June 30, 2014 Nick are you in the pnw? If so you should come out and help with the "little" project. 1 Link to comment Share on other sites More sharing options...
19804wdPOS Posted June 30, 2014 Author Share Posted June 30, 2014 On 6/24/2014 at 9:51 PM, Vegablade said: Don't just cut the axle. Remove the whole cage assembly from the cup. Just leave the cup and attached axle piece through the hub. I always keep a couple of these laying around, just in case. I do warn you again that you will be putting lots of extra strain on the diff. I exploded a welded diff with 26" tires. Also these. Link to comment Share on other sites More sharing options...
19804wdPOS Posted June 30, 2014 Author Share Posted June 30, 2014 On 6/24/2014 at 9:51 PM, Vegablade said: Don't just cut the axle. Remove the whole cage assembly from the cup. Just leave the cup and attached axle piece through the hub. I always keep a couple of these laying around, just in case. I do warn you again that you will be putting lots of extra strain on the diff. I exploded a welded diff with 26" tires. Also these. I can't open any of the links.How does one go about taking out the cage assembly? Link to comment Share on other sites More sharing options...
nick1208 Posted June 30, 2014 Share Posted June 30, 2014 On 6/30/2014 at 12:57 AM, 19804wdPOS said: Nick are you in the pnw? If so you should come out and help with the "little" project. yes I am. PM me Link to comment Share on other sites More sharing options...
Turbone Posted June 30, 2014 Share Posted June 30, 2014 On 6/27/2014 at 4:32 AM, Gloyale said: I Think you mean transfer gear.....not the ring gear in the front diff correct??? I welded my transfer gear collar rigth to the gear to keep maximum engagement on the teeth in my T-cased rig.......no need to use the FWD option. But that is T-cased not really relavent here. Oops, without actually tearing into the trans I'm sure you're correct Link to comment Share on other sites More sharing options...
Vegablade Posted June 30, 2014 Share Posted June 30, 2014 This is what happened to his car. He emailed me this. I explained to him how it would be far easier in the long run to just fix it right and be done with it. RWD is fun, but only if its done right. Link to comment Share on other sites More sharing options...
Gloyale Posted June 30, 2014 Share Posted June 30, 2014 On 6/30/2014 at 2:36 PM, Vegablade said: This is what happened to his car. He emailed me this. That look overextended to me. Aftermarket tripod joint for sure....but I don't see anything "broken" Does that car have an "over stock" lift?? Link to comment Share on other sites More sharing options...
19804wdPOS Posted June 30, 2014 Author Share Posted June 30, 2014 On 6/30/2014 at 3:20 PM, Gloyale said: That look overextended to me. Aftermarket tripod joint for sure....but I don't see anything "broken" Does that car have an "over stock" lift?? I believe that it is stock but I am not sure. Link to comment Share on other sites More sharing options...
TOONGA Posted July 4, 2014 Share Posted July 4, 2014 On 6/24/2014 at 6:04 PM, 19804wdPOS said: I'm probably going to do this. So do i need stubs or can i just remove the front axles that attach to the knuckle? You need the outer CV joints so that the wheels roll and your steering works. TOONGA Link to comment Share on other sites More sharing options...
sumoco Posted July 11, 2014 Share Posted July 11, 2014 So I just bought a 80 hatchback that was converted into a rwd drift machine. The dude before me had taken the innards from a single range loyal tranny and put them into an ej22 bell housing, chopped and welded the front axle nubs and lowered it so it sits about 5 inches off the ground. It's about to have my ej22 dropped in and we shall see how well it actually handles Link to comment Share on other sites More sharing options...
nick1208 Posted July 11, 2014 Share Posted July 11, 2014 On 7/11/2014 at 1:10 AM, sumoco said: So I just bought a 80 hatchback that was converted into a rwd drift machine. The dude before me had taken the innards from a single range loyal tranny and put them into an ej22 bell housing, chopped and welded the front axle nubs and lowered it so it sits about 5 inches off the ground. It's about to have my ej22 dropped in and we shall see how well it actually handles Is this the red one on white wheels? Pics? Link to comment Share on other sites More sharing options...
sumoco Posted July 11, 2014 Share Posted July 11, 2014 Nope it's a white one from Yakima Washington, it's covered in stickers( in the process of removing them) and has the rear windows tinted Link to comment Share on other sites More sharing options...
19804wdPOS Posted July 18, 2014 Author Share Posted July 18, 2014 I fixed the чертовскй cv axle and it broke after half a mile. I think my car was destined to be rwd. Link to comment Share on other sites More sharing options...
Gloyale Posted July 19, 2014 Share Posted July 19, 2014 On 7/18/2014 at 5:54 PM, 19804wdPOS said: I fixed the чертовскй cv axle and it broke after half a mile. I think my car was destined to be rwd. You did something wrong. Miss one of the rings on that Tripod? Should....Get rid of the stupid aftermarket crap tripod axle anyhow. Do it right with a good axle and it should not break. Link to comment Share on other sites More sharing options...
19804wdPOS Posted July 19, 2014 Author Share Posted July 19, 2014 I put a new oem cv axle in. I followed every step. It happened again. Link to comment Share on other sites More sharing options...
sumoco Posted July 19, 2014 Share Posted July 19, 2014 RWD!!!!!!!!!!!! 1 Link to comment Share on other sites More sharing options...
Uberoo Posted July 20, 2014 Share Posted July 20, 2014 what about this rwd EJhatch? Link to comment Share on other sites More sharing options...
sumoco Posted July 20, 2014 Share Posted July 20, 2014 Still trying to find time to slam my ej22 into it, been slammed with work. Going to try to bring it up to wcss Link to comment Share on other sites More sharing options...
rallybeast22 Posted June 3, 2015 Share Posted June 3, 2015 On 6/27/2014 at 4:32 AM, Gloyale said: I Think you mean transfer gear.....not the ring gear in the front diff correct??? I welded my transfer gear collar rigth to the gear to keep maximum engagement on the teeth in my T-cased rig.......no need to use the FWD option. But that is T-cased not really relavent here. How do you weld the transfer gear collar to the gear? I have to replace my rwd s/r gear box every year or soo. Link to comment Share on other sites More sharing options...
