Fuel pump fuel line quick connect
98 forester, strong gas odor. Digging around and found the leak is coming from the quick connector located right on top of fuel pump.
Is this a common place for gas to leak/sipping thru? I am assume I will need a new connector? Any suggestion?
Thanks
what Faritax said - and it can be a real bear to get that connector apart.
This is what it looks like when you do get it apart...
you are supposed to be able to squeeze the white part to slide the hose side off...I had to do a fair amount of digging with a dental pick to get enough rust out of there to be able to separate mine.
