EA 82 shift linkage
ok if you are looking up from under the car at the shift linkage you will see what i think
is a pin so you can remove the linkage from the trans how in the hell do you get that pin out
i hope this is a nuff info 4 any of you if i need to i will post picks
thanks 2 you all 4 help
roll pin ?? I have always undone a few bolts such as a pair of 14mm heads bolting stay bracket to lower back face of gearbox and a few 12mm head bolts going through bushes and this allows the box to be free of the shifters of 4WD DR as far as I recall, shifters just hang free with body,box come out ..... ???
When I installed for first time I painted up bolts, nuts and parts they go through, bit like the factory assembly ID colours - to assist my brain while upside down under car :)
