angerthis Posted June 27, 2014 Share Posted June 27, 2014 ok if you are looking up from under the car at the shift linkage you will see what i think is a pin so you can remove the linkage from the trans how in the hell do you get that pin out i hope this is a nuff info 4 any of you if i need to i will post picks thanks 2 you all 4 help Link to comment Share on other sites More sharing options...
Gloyale Posted June 27, 2014 Share Posted June 27, 2014 Put it in Reverse will help access it. Then use a long punch. It's actually 2 pins.....drive out the small one first, then the big one so 2 punches Link to comment Share on other sites More sharing options...
angerthis Posted June 27, 2014 Author Share Posted June 27, 2014 so that nub that sticks out the bottom you drive it out from what way? Link to comment Share on other sites More sharing options...
jono Posted June 27, 2014 Share Posted June 27, 2014 roll pin ?? I have always undone a few bolts such as a pair of 14mm heads bolting stay bracket to lower back face of gearbox and a few 12mm head bolts going through bushes and this allows the box to be free of the shifters of 4WD DR as far as I recall, shifters just hang free with body,box come out ..... ??? When I installed for first time I painted up bolts, nuts and parts they go through, bit like the factory assembly ID colours - to assist my brain while upside down under car Link to comment Share on other sites More sharing options...
