legacy603 Posted June 27, 2014 Share Posted June 27, 2014 (edited) OK so I found the leak well more like waterfall right close to the driver side knuckle and need a temp fix until payday any ideas would be great its a 97 legacy LSI Edited June 27, 2014 by legacy603 Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted June 27, 2014 Share Posted June 27, 2014 (edited) JBWeld, get the putty and just make a ball around the line and squeeze it. do not squeeze too hard, you don't want it to squeeze into the line. probably should clean the outside of the line first. ps: some on probably has used lines for cheap. Edited June 27, 2014 by johnceggleston Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 27, 2014 Share Posted June 27, 2014 JBWeld, get the putty and just make a ball around the line and squeeze it. do not squeeze too hard, you don't want it to squeeze into the line. probably should clean the outside of the line first. ps: some on probably has used lines for cheap. good idea to use JB. Recommend you clean the application spot as much as possible. Apply, then, let car sit over night to dry the JB, before driving again. Quote Link to comment Share on other sites More sharing options...
legacy603 Posted June 27, 2014 Author Share Posted June 27, 2014 I'll give it a try tonight thanks guys Quote Link to comment Share on other sites More sharing options...
