AKghandi Posted June 28, 2014 Share Posted June 28, 2014 85 ea82 wagon 2" lift. i was told i can do 5/8" without an issue by my friend Bodey, he used to wheel with the washington crew but is now here in ak. anyways i picked up some half inch spacers and some washers which should equal about 5/8. my car is the manual rack. Link to comment Share on other sites More sharing options...
peacewize Posted July 3, 2014 Share Posted July 3, 2014 I have the variable manual rack and I dropped my engine 1 and 1/4" and my trans 1". No problems just loosen the bolts and slide it out while your dropping it. Looks like it only moved less than 1/2" on the steering column shaft Link to comment Share on other sites More sharing options...
AKghandi Posted July 3, 2014 Author Share Posted July 3, 2014 i have the same rack an i just dropped it 3/4" so maybe i can do more if need be. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 3, 2014 Share Posted July 3, 2014 pick up a legacy steering knuckle they are a bit longer Link to comment Share on other sites More sharing options...
