AKghandi Posted June 28, 2014 Share Posted June 28, 2014 85 ea82 wagon 2" lift. i was told i can do 5/8" without an issue by my friend Bodey, he used to wheel with the washington crew but is now here in ak. anyways i picked up some half inch spacers and some washers which should equal about 5/8. my car is the manual rack. Quote Link to comment Share on other sites More sharing options...
peacewize Posted July 3, 2014 Share Posted July 3, 2014 I have the variable manual rack and I dropped my engine 1 and 1/4" and my trans 1". No problems just loosen the bolts and slide it out while your dropping it. Looks like it only moved less than 1/2" on the steering column shaft Quote Link to comment Share on other sites More sharing options...
AKghandi Posted July 3, 2014 Author Share Posted July 3, 2014 i have the same rack an i just dropped it 3/4" so maybe i can do more if need be. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 3, 2014 Share Posted July 3, 2014 pick up a legacy steering knuckle they are a bit longer Quote Link to comment Share on other sites More sharing options...
