maximum crossmember drop without lengthing steering?
85 ea82 wagon 2" lift.
i was told i can do 5/8" without an issue by my friend Bodey, he used to wheel with the washington crew but is now here in ak.
anyways i picked up some  half inch spacers and some washers which should equal about 5/8.
my car is the manual rack.
I have the variable manual rack and I dropped my engine 1 and 1/4" and my trans 1". No problems just loosen the bolts and slide it out while your dropping it. Looks like it only moved less than 1/2" on the steering column shaft
