brus brother Posted July 6, 2014 Share Posted July 6, 2014 Subaru Recall NY Times article link Probably just being overly cautious but please don't tailgate too close to me just in case. My 05 and 08 were part of the earlier recall but apparently the powers that be deemed even that to be ineffective. Just for the northern states with salty roads. Link to comment Share on other sites More sharing options...
ferret Posted July 6, 2014 Share Posted July 6, 2014 brake line recall WQK-47, only affects salt-belt state carsThere is the possibility of brake line corrosion when the brake line isexposed to salt water in the cold weather, salt-belt states ofConnecticut, Delaware, Wa, D.C.,Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan,Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio,Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin.Salt water could splash on the brake lines through a gap in the fueltank protector, resulting in possible excessive corrosion and leakingbrake fluid which could affect stopping distances. Drivers should becareful, check the brake fluid, and watch for the dashboard brake lampwarning light.Years include some 2005-2009 Outback and Legacy, 2008-2011 Impreza (notWRX, STI), 2008-2014 WRX and STI, and 2009-2013 Foresters.Owners will be notified by mail, and dealers cannot sell any cars subject to the recall.This is recall #WQK-47 (note- this recall is similar recall #WGQ-43 for the 2005-2009 Outback/Legacy in April 2013) Link to comment Share on other sites More sharing options...
ferret Posted July 6, 2014 Share Posted July 6, 2014 And ANOTHER Recall just after the one I Posted: some 2003-2004 Outback, Legacy, Baja, Impreza, WRX/STIthe recall is to replace some improperly manufactured front passenger airbag inflators on some (not all) of these models.This is recall WQL-48 2003-2004 some but not all Outback, Legacy, Baja, Impreza, WRX/STI2003 Legacy built 1/22/03-5/14/032004 Legacy built 3/17/03-2/10/042003 Outback built 2/18/;04-4/15/032004 Outback built 2/28'03-2/11/042003 Baja built 2/11/03-5/6/032004 Baja built 3/3/03-7/21/04Impreza, WRX, STI built 1/8/03-5/15/03 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 6, 2014 Share Posted July 6, 2014 (edited) And ANOTHER Recall just after the one I Posted: some 2003-2004 Outback, Legacy, Baja, Impreza, WRX/STI the recall is to replace some improperly manufactured front passenger airbag inflators on some (not all) of these models. This is recall WQL-48 2003-2004 some but not all Outback, Legacy, Baja, Impreza, WRX/STI 2003 Legacy built 1/22/03-5/14/03 2004 Legacy built 3/17/03-2/10/04 2003 Outback built 2/18/;04-4/15/03 2004 Outback built 2/28'03-2/11/04 2003 Baja built 2/11/03-5/6/03 2004 Baja built 3/3/03-7/21/04 Impreza, WRX, STI built 1/8/03-5/15/03 some of those dates look odd. got a link to the data? Edited July 6, 2014 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
ferret Posted July 6, 2014 Share Posted July 6, 2014 http://www.cars101.com/recalls.html Link to comment Share on other sites More sharing options...
mikec03 Posted July 6, 2014 Share Posted July 6, 2014 Just to alert all, I have had two late 90's subarus that developed leakes on the rear brake lines. So rusting out rear brake lines, in northern states, on ALL subarus is probably going to become a common complaint as these cars age. Unfortunately, my cars were not subject to a recall. The brake lines should be ss in my opinion. It's kind of a dangerous condition. 1 Link to comment Share on other sites More sharing options...
ferret Posted July 6, 2014 Share Posted July 6, 2014 (edited) Being a neighborhood mechanic, I can atttest to the fact, it is ALL manufacturers. I just did our neighbors 2003 Chevy 1500 pickup. Also a lot of Ford products. So it's not limited to Subarus. I AM surprised they stepped up to a recall. Edited July 6, 2014 by ferret 1 Link to comment Share on other sites More sharing options...
myhilo Posted July 6, 2014 Share Posted July 6, 2014 The brake line corrosion also applies to the fuel lines and the fuel vent lines. The salt belt cars should all be built to prevent such unsafe failures. It's just a matter of using cheap piping in the manufacture. A few dollars more to use any more durable alloy would have taken care of the problem. I had to do this job on a 97 Honda Accord and did a little research. Next time I need to do a job like this I plan on buying enough supplies from a source such as: http://store.fedhillusa.com/ There are other vendors with different alloys. I have had a lot of industrial experience with stainless steel as well. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 7, 2014 Share Posted July 7, 2014 Stainless steel generally does not have the pressure capacity for automotive brake lines. It can when its new, but bending the line weakens it. But there are plenty of alloys out there that have a high burst strength and can maintain that strength after bending, while also being able to withstand a corrosive environment. Link to comment Share on other sites More sharing options...
fgf Posted July 7, 2014 Share Posted July 7, 2014 The weak spot in my 95-03 Legacy and Outbacks seems to be the brake lines which exit the body under the back seat and then run above the gas tank to the rear wheels. Salt and sand park up there and eat the lines (and the gas tank)... I've taken to using cupro nickel brake lines. They are said to be much more resistant to corrosion and do seem easier to bend without kinking. There is a good summary at <http://www.copper.org/applications/automotive/brake-tube/brake.html> I've ordered mine from <http://www.ribetautoparts.com/>, about $25 for a 25' roll of 3/16. About 2X the cost of plain steel line, but that hardly matters when compared to the high labor and time costs of installing new lines. 2 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 7, 2014 Share Posted July 7, 2014 http://www.cars101.com/recalls.html Still seems like the date's got scrambled for the Outback - couldn't find the WQL-48 at NHTSA either. maybe too soon to show up? Link to comment Share on other sites More sharing options...
brus brother Posted July 8, 2014 Author Share Posted July 8, 2014 Being a neighborhood mechanic, I can atttest to the fact, it is ALL manufacturers. I just did our neighbors 2003 Chevy 1500 pickup. Also a lot of Ford products. So it's not limited to Subarus. I AM surprised they stepped up to a recall. GM refuses recall. Subaru cited as doing the right thing! http://www.nytimes.com/2014/07/08/automobiles/gm-resists-recalling-trucks-over-brake-line-problem.html?hp&action=click&pgtype=Homepage&version=HpSumSmallMedia&module=first-column-region®ion=top-news&WT.nav=top-news&_r=0 Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 8, 2014 Share Posted July 8, 2014 I just replaced a rear brake line on a 2004 Silverado a few weeks ago at work. It was rusted badly in multiple areas the entire length of the line from the ABS module, which is mounted under the drivers floor board, all the way to the rear axle. It had blown out just above the fitting where it joins the rubber hose going to the axle. The other lines that went to the ABS module were also rusted, though not nearly as badly as the rear brake line. Link to comment Share on other sites More sharing options...
gregB Posted July 8, 2014 Share Posted July 8, 2014 Had my 2002 2500HD done in Feb this year. Paid the shop for labor and provided the GM pre-bent kit for the lines. Looks like OEM, hopefully it will last longer this go round. Most of the lines were so rusted that pulling on them cracked the tubing Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 10, 2014 Share Posted July 10, 2014 (edited) Still seems like the date's got scrambled for the Outback - couldn't find the WQL-48 at NHTSA either. maybe too soon to show up? Outback dates; 2003 Outback 02/18/2003 04/15/2003 2004 Outback 02/28/2003 02/11/2004 from; www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM458062/RCDNN-14V399-5724.pdf My car's sticker on the driver's door just says 4/03 . Is there a date somewhere with the specific day? anyway, we haven't moved since we bought the car so, I may just watch for a letter. Edited July 10, 2014 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
CNY_Dave Posted July 11, 2014 Share Posted July 11, 2014 I just did my '03 OBW rear brake lines, one let loose a few weeks ago. Link to comment Share on other sites More sharing options...
brus brother Posted July 11, 2014 Author Share Posted July 11, 2014 I just did my '03 OBW rear brake lines, one let loose a few weeks ago. I'd gather up the bills and present it to Subaru and see what they say. Link to comment Share on other sites More sharing options...
CNY_Dave Posted July 11, 2014 Share Posted July 11, 2014 I'd gather up the bills and present it to Subaru and see what they say. Relatively few bucks for 2 pieces of steel line, some $$ for a bunch of hours on my back, and a swear-jar bill for $40,000 sounds about right. 2 Link to comment Share on other sites More sharing options...
Sajawa Posted January 8, 2015 Share Posted January 8, 2015 New (second) recall just announced. First repair not always sufficient. Will now wax brake line to prevent moisture from forming rust. Link to comment Share on other sites More sharing options...
