84 EA81 rough idle questions.
  • 2 weeks later...
Forgot to say already have new plugs, wires, cap and rotor, and fuel filters. The tach jumps up and down at idle also.
In that case,remove the cap and see how much sideplay the distributor shaft has.
Should be very little.
Anything more than barely perceptible is too much.
The reluctor air gap is only .020" maximum.
The jumping tach is a dead give away that you need new distributor bushings or a new disty.
  • Like 1
