nlucchesini Posted July 6, 2014 Share Posted July 6, 2014 Hi.car was running fine with some bugs to be tuned. It first started when i cleaned the maf and ground points, car was running like crap but no misfire just bad idle that cleared after 3000 rpmlater that night i started the car and magically it was all good but i did notice that the car was running very rich, 12-12.5 at idle, i went for a ride and afr was stable at 11-11.2 all the timethen after 8 miles suddently misfired and its ran like it was only with 2 pistons.went to the mechanic and they found out that pistons 1 and 3 where off.So we took out the spark plugs and the right side ones were completly black and soaked in gas and the left side were almost like new.No cell, but days before got misfire con cylinder 1,3,4Later we did this with no result:Changed spark plugsChanged coils Changed maf sensorChecked injector pluseChecked coil with plug for sparkChecked timingChecked ground Checked compression (140 psi on all 4)What could possibly be shutting down one side of the engine ? please help beacuse we have no clue.Mods are:wallbro 255 fuel pumpID 1000cc top feed conversion with fuel lines, stock FRP (recently installed)Ks tech big maf short ram itankeBlouch dom 3xtrGt spec header with invidia turbo back exhaustBig top mount intercoolerEcu reflash Wiseco pistons (recently installed)Manley rodsPorted head (recently installed)GSC 272 cams (recently installed)GSC Valves (recently installed)GSC springs and retainers (recently installed)Car was breaking in new pistons, just traveled 20 miles no wot Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 6, 2014 Share Posted July 6, 2014 Fouled plugs could mean they're too cold. Might need a higher heat plug for the break-in. AFR at 11.2 is pig rich. Is it getting out of open loop at the correct temp? Link to comment Share on other sites More sharing options...
Gloyale Posted July 6, 2014 Share Posted July 6, 2014 Camshaft is the link between 1-3 cylinders. Link to comment Share on other sites More sharing options...
nlucchesini Posted July 6, 2014 Author Share Posted July 6, 2014 i logged the INTAKE AVCS ADVANCE and found that right one was advancing 66 degrese. Could that be the cause ? Damaged selenoid? Stuck sprocket? Link to comment Share on other sites More sharing options...
nlucchesini Posted July 6, 2014 Author Share Posted July 6, 2014 Forgot to mention, unplugging the selenoid made no difference Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 7, 2014 Share Posted July 7, 2014 don't 05s have oil screens in the AVCS system as well as the turbo bearing? Link to comment Share on other sites More sharing options...
nlucchesini Posted July 7, 2014 Author Share Posted July 7, 2014 I have checked my VIN and it doesnt have oil screen on the avcs but it does have on the turbo. Turbo and AVCS use a common rail? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 7, 2014 Share Posted July 7, 2014 can those solenoids be swapped left to right? or the sensors? Link to comment Share on other sites More sharing options...
zombieforce Posted July 7, 2014 Share Posted July 7, 2014 (edited) Yes they can I have done it when I was chasing a misfire on an xt engine. Are there any cam crank correlation codes ? I had an intake gear put on that had an egg shaped dowel pin hole so even tho it was basically in time it was off just enough to cause mis fires down low. Ran fine in the revs. Just had a bad idle. Also isnt 140 psi compression a bit low for pistons? Edited July 7, 2014 by zombieforce Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 8, 2014 Share Posted July 8, 2014 Wiseco are lower compression ratio pistons. 140 isn't out of the ballpark for a built turbo motor. Quote i logged the INTAKE AVCS ADVANCE and found that right one was advancing 66 degrese. How far is the left side advancing? Link to comment Share on other sites More sharing options...
zombieforce Posted July 8, 2014 Share Posted July 8, 2014 On 7/8/2014 at 4:13 AM, Fairtax4me said: Wiseco are lower compression ratio pistons. 140 isn't out of t. ballpark for a built turbo motor. How far is the left side advancing? Yeah I guess thats right. Im stuck thinki g about my jet ski engines any less than 180 psi and you can feel the loss of power Link to comment Share on other sites More sharing options...
