joshtalo Posted July 6, 2014 Share Posted July 6, 2014 Hey all, I just installed an EJ22EAWBPL engine, taken from a 96 outback legacy (manual), into a different 96 outback legacy (automatic) that previously had an EJ25DAABJL. When I start it up, the engine constantly revs up to 3K rpm, then drops a little, then revs back up. It will do this until it is shut off. I can't figure out for the life of me why it's doing this. Any ideas? Link to comment Share on other sites More sharing options...
johnceggleston Posted July 6, 2014 Share Posted July 6, 2014 double check ALL of the vac hoses. you left something open, disconnected. you may end up with a trouble code due to no EGR. Link to comment Share on other sites More sharing options...
Rooster2 Posted July 7, 2014 Share Posted July 7, 2014 double check ALL of the vac hoses. you left something open, disconnected. you may end up with a trouble code due to no EGR. Same thought, a disconnected vacuum hose somewhere causes what you describe. You may have a vacuum hose that is partially cut open that could be the culprit. Also agreed, the 5 speed engine prolly does not have an EGR, where as the automatic does have an EGR. That prolly will trigger a check engine light. There are ways to fix this, if it presents itself to you. Link to comment Share on other sites More sharing options...
