turbosubarubrat Posted July 23, 2014 Author Share Posted July 23, 2014 Nice brat! Um you do know the caliper pistons screw in right? They don't slide in and out like a regular caliper since the park brake is up front. Learned that the hard way myself. I tried screwing it in for 20 minutes with no luck so i took off then i hit it twice with sledge and put it back together. Once it was bled i tested it out to make sure it was working right which it was. I test brakes on gravel so i can tell what brakes are grabbing from the skid trails from hard stops. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 2, 2014 Author Share Posted August 2, 2014 Just got the title in the mail today and went up to DMV to get the title transferred. 2 Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted August 12, 2014 Share Posted August 12, 2014 Glad someone on here got that BRAT. I saw it on Craigslist, but really don't have anywhere to keep it or work on it otherwise I would have called them the second I saw the ad. Nice that it has Cruise and AC. If it had Power Steering it would be awesome. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 16, 2014 Author Share Posted August 16, 2014 (edited) plug mount made. welded on to the hitch and painted. Edited November 23, 2014 by turbosubarubrat Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 16, 2014 Author Share Posted August 16, 2014 (edited) Fixed the dip stick. replacement reverse light switch from pick n pull. took off the front plate and put it on the dash. original reverse switch broke a terminal. While i was down there i drain the transmission fluid and put in new 80 90w Edited November 23, 2014 by turbosubarubrat Link to comment Share on other sites More sharing options...
Bratworst82 Posted October 19, 2014 Share Posted October 19, 2014 Wish I hadn't found this thread. That is what my Brat was supposed to look like. I bought mine off Craigslist about two winters ago for $50. After renting a tow dolly and gas, I was all in for $120. I knew it was really rusty but didn't know how bad until I went to pick it up. 1/3rd of the bed was gone including most of the wheel wells. I decided to part it out and after two years have made over a grand! 1 Link to comment Share on other sites More sharing options...
turbosubarubrat Posted November 23, 2014 Author Share Posted November 23, 2014 Towed her down to DEQ today and passed . Planning on going to DMV on monday and getting new plates and tags then to state farm to get insurance swapped back on. Moved the the front snow tires(studs pulled they came that way on the brat) to the rear and put a set of stud less snow tires on the front. Also washed her down and cleaned out the bed since i'm going to start stripping it to prime and bed line maybe tomorrow depending if the bed is dry or not. The radio still needs a adapter plate made which might happen tomorrow also. Test results: Hydrocarbons 55, standard 220 Carbon monoxide 0.185, standard 1.0 1 Link to comment Share on other sites More sharing options...
turbosubarubrat Posted November 23, 2014 Author Share Posted November 23, 2014 Fixed all the pics in the thread. Also forgot to mention i ordered a dash cover for this off jc whitney it should be here sometime next week. 2 Link to comment Share on other sites More sharing options...
turbosubarubrat Posted December 8, 2014 Author Share Posted December 8, 2014 (edited) Here's the cat i welded in before i brought it into DEQ. Prepped bed. primed. Bed lined. Dash mat in. Trim and covers bad on. The bed covers are slightly darker in the pics because of flash and same with the glare. Finally made radio adapter plate. Edited December 8, 2014 by turbosubarubrat 2 Link to comment Share on other sites More sharing options...
Hsoj Posted December 8, 2014 Share Posted December 8, 2014 How do you like the fit of the dash mat? Link to comment Share on other sites More sharing options...
turbosubarubrat Posted December 8, 2014 Author Share Posted December 8, 2014 How do you like the fit of the dash mat? It fits good but would straighten out better if the dash didn't have a huge crack that raises it up a inch. Link to comment Share on other sites More sharing options...
Sapper 157 Posted December 10, 2014 Share Posted December 10, 2014 Nice brush guard you got on there. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted December 10, 2014 Author Share Posted December 10, 2014 Today i got a set of Support Our Troops plates transferred on to the brat today, new tags, and registration. I had some trouble getting them to put them on since the plates got out of the system since they stopped making them/issuing them. They had to run a search on the plates and put them back in the system. Plus you had to have the plates on a vehicle you owned or they will not let you use them because they are not issued anymore. They came on my 85 brat when i got so i was set on that part. I just need to mount them tomorrow and take her for a spin. Nice brush guard you got on there. I have a identical one on my hatch back that's very straight that i put a winch on. Both are factory brush guards which are hard to find. I still need to straighten out my factory winch bumper for my 85 brat... Link to comment Share on other sites More sharing options...
turbosubarubrat Posted January 1, 2015 Author Share Posted January 1, 2015 monstaru is the proud new owner of this little beast. Link to comment Share on other sites More sharing options...
