c5h5nino Posted July 9, 2014 Share Posted July 9, 2014 Good afternoon All, I have been looking around for specific dimensions of strut towers for a lift (3"). I haven't found much, and I have asked a few people which went no where. So here it is, I did some measuring, modeling, and drafting and this is what I came up with. Please let me know how I did? If I need to make changes let me know... Best, Lewis Link to comment Share on other sites More sharing options...
sumoco Posted July 9, 2014 Share Posted July 9, 2014 Thank you very much, a lot of people are very rude when you ask them about things like this Link to comment Share on other sites More sharing options...
Vegablade Posted July 9, 2014 Share Posted July 9, 2014 (edited) I can't remember off the top of my head but don't the top and bottom plates have to offset to clear? Stole This From Scott Edited July 9, 2014 by Vegablade Link to comment Share on other sites More sharing options...
c5h5nino Posted July 9, 2014 Author Share Posted July 9, 2014 that makes sense, I thought they were offset for ease of installing the bolts, but I could be wrong...I haven't installed a lift yet. I am in the process of measuring, modeling and drafting and then some fabing. Just want the experts to look over the prints first. I am willing to draft it all up and have it publicly available to whomever.... Thanks, Lewis Link to comment Share on other sites More sharing options...
djellum Posted July 9, 2014 Share Posted July 9, 2014 One corner will make it super tight to fit cause it will contact the side of the strut tower if your not carefull. Id rotate the bottom for max clearance there 1 Link to comment Share on other sites More sharing options...
El Presidente Posted July 10, 2014 Share Posted July 10, 2014 When I make strut lifts, I set the angle at 17-18* instead of 15*. The negative camber you gain helps with on-road manners. I'm pretty sure 15* will get you positive camber, which gets really annoying. Josh 1 Link to comment Share on other sites More sharing options...
Gloyale Posted July 11, 2014 Share Posted July 11, 2014 The 3 bolt holes are an even triangle.....looks like you;ve got them slightly off. Link to comment Share on other sites More sharing options...
c5h5nino Posted July 14, 2014 Author Share Posted July 14, 2014 Good morning all, Thanks for all the information. I rotated the bottom plate, so it is parallel with the frame. I also increased the angle to 17°. Attached is the updated drawing reflecting the changes please let me know how it looks? I plan on building the lift components on Friday and installing them this weekend. I will take pictures and continue to update this thread. Does any one know the dimensions of the angled pieces that drop the rear struts (picture above)? I would like to draw up the rest of the components (rear strut brackets and frame spacers), so myself and future members can have the information at their finger tips. Gloyale, I measured the distance of the holes they are all 4.85 apart. The 4.2 dimension is a rise distance not an aligned distance between holes (please see the attached drawing). Link to comment Share on other sites More sharing options...
sumoco Posted July 20, 2014 Share Posted July 20, 2014 If I'm making an ea81 lift do I need to offset the top and bottom since it isn't a triangle? Link to comment Share on other sites More sharing options...
Henpecked Posted July 20, 2014 Share Posted July 20, 2014 (edited) Yes , as is said above , it needs about 6mm offset for every 1" of lift ( mixed metric/imperial - sorry) to get the right camber On 7/20/2014 at 12:49 AM, sumoco said: If I'm making an ea81 lift do I need to offset the top and bottom since it isn't a triangle? Edited July 20, 2014 by Henpecked Link to comment Share on other sites More sharing options...
Tman1058 Posted July 21, 2014 Share Posted July 21, 2014 (edited) On 7/20/2014 at 4:17 AM, Henpecked said: Yes , as is said above , it needs about 6mm offset for every 1" of lift ( mixed metric/imperial - sorry) to get the right camber6mm=~1/4"And 2.54cm=1" Edited July 21, 2014 by Tman1058 Link to comment Share on other sites More sharing options...
