ginafish33 Posted July 11, 2014 Share Posted July 11, 2014 First off, thank you for your time! My '96 Subaru Impreza has had an issue for the past few years where it will randomly not start. It can go at least 20 times starting/running normally, before it does not start. The problem started about 2 and a half years ago. I immediately thought it was the battery and replaced it. No change. I then replaced the battery cables. No change. I replaced the starter, no change. When I turn the car on, all of the dashboard lights/radio/headlights function normally. However, when I try to start the car, there will be one click, then nothing (headlights also do NOT dim). It does not try to "turn over" and there are not multiple clicking sounds. After about 5 or 10 minutes of scratching my head, it will turn on normally as if nothing had happened. I figure the only thing left it could be is the ignition switch. I just wanted to get advice before I brought it into a shop and spent all my money to get it fixed. Thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 11, 2014 Share Posted July 11, 2014 Manual or auto trans? The starters in these are not known for mechanical failures but the electrical contacts in them do wear and can cause this problem. Was the replacement starter used or a rebuild? Link to comment Share on other sites More sharing options...
ginafish33 Posted July 11, 2014 Author Share Posted July 11, 2014 Automatic transmission. It was a rebuild starter. Does it even sound like it could be an ignition switch problem? Link to comment Share on other sites More sharing options...
lmdew Posted July 11, 2014 Share Posted July 11, 2014 Next time it happens, try putting it in Neutral and see if it doesn't start normally. Link to comment Share on other sites More sharing options...
lmdew Posted July 11, 2014 Share Posted July 11, 2014 I don't have any time until the first week of AUG, but if you can live with it that long, I'd be happy to take a look for you. Larry Link to comment Share on other sites More sharing options...
mikec03 Posted July 11, 2014 Share Posted July 11, 2014 Sometimes on older subarus, the electrical current to the starter solenoid is not sufficient to completely close the contacts. The voltage is OK, when tested. It just does not have enough current. I had to add a relay as described as follows on a couple of 90's subarus. This is copied from from an older post. It's a fairly common problem. Maybe, but before i spent $75 on a replacement starter, i would try therelay fix. the parts are cheap and it doesn't take long to try it.1 - relay (generic head light relay will do just fine)1- wire pigtail w/ inline fuse (from the the battery to the relay)1 - ground wire (from the relay to the chassis)1 - jumper wire pigtail (from relay to starter) 6 - 8 - female spade connectorsno existing wires to cut, install the relay in line between the existing''small wire'' on the starter and the starter. power it from thebattery, fused, and run a ground wire. if it works great. if not justdisconnect it and you have spent ~$12 diagnosing your problem.but my bet is that the relay will work. this is not an uncommon problem for subarus, 80s - 90s. Link to comment Share on other sites More sharing options...
ginafish33 Posted July 11, 2014 Author Share Posted July 11, 2014 Thank you all for your help! I will try both fixes and update you the next time my Subie acts up. Link to comment Share on other sites More sharing options...
