1-3-2-4 Posted July 11, 2014 Share Posted July 11, 2014 I was wondering is the switch just used to know when the pedal is depressed or does it tie into the ECU? I don't have the wire diagram on my laptop. My switch is going Link to comment Share on other sites More sharing options...
Gloyale Posted July 11, 2014 Share Posted July 11, 2014 Clutch switches....... one for Starter lockout... one for Cruise cancel... ECU doesn't care doesn't see clutch switch.......does see "nuetral" switch though. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 11, 2014 Author Share Posted July 11, 2014 So the one for starter lockout is just that and nothing with the ecu right? Link to comment Share on other sites More sharing options...
Gloyale Posted July 11, 2014 Share Posted July 11, 2014 So the one for starter lockout is just that and nothing with the ecu right? Correct ECU doesn't see anything from clutch switch on EJ's Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 12, 2014 Author Share Posted July 12, 2014 Ah ok I picked up a new clutch switch Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 Uh-oh.. I replaced the switch thinking it was ok.. so I had a large deposit at a ATM so I turned off the car, when it was time to leave again I tried to start and it was no go.. I found if I keep pushing and letting the clutch pedal go it will start up.. so now I don't know where to check next? Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 13, 2014 Share Posted July 13, 2014 When it doesn't start do you hear a buzzing sound from under the dash? Have you made sure the wire connection on the starter is clean? Does the starter click at all when this happens? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 When it doesn't start do you hear a buzzing sound from under the dash? Have you made sure the wire connection on the starter is clean? Does the starter click at all when this happens? No buzz no clicking at all.. all I hear is just the relays but if I start pumping the clutch it was then soon somehow make a connection and the starter gets power. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 13, 2014 Share Posted July 13, 2014 Pumping the clutch while still holding the key in start? That sounds like the interlock relay is bad, and the repeated on/off of the clutch switch finally makes the relay click and start working. The relay is grounded by the clutch switch. When the key is turned the relay is powered by the ignition switch start position, and the relay delivers the 12v start signal to the starter solenoid. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 Do you have a part number for it? Link to comment Share on other sites More sharing options...
Gloyale Posted July 13, 2014 Share Posted July 13, 2014 Just jumper the Red/Yellow and Blue/red wires at the interlock relay to bypass. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 It's like a 100 wires in where should I be looking.. it's happening right now and I'm parked in a area I can't move easy Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 Also I don't know where the interlock is as well Link to comment Share on other sites More sharing options...
Gloyale Posted July 13, 2014 Share Posted July 13, 2014 Also I don't know where the interlock is as well It's a big brownish/yellow relay with a blue plug. Remove the 2 screws that hold the under column panel, then remove that........it's right behind that on the left of the column. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 It's yellow with a red/yellow and two blue/red cables. I feel the relay clicking Link to comment Share on other sites More sharing options...
Gloyale Posted July 13, 2014 Share Posted July 13, 2014 hmm......possible the starter solenoid is dying......although you should be hearing it click at least if the interlock and key are working. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 13, 2014 Author Share Posted July 13, 2014 It's not I replaced the plunger and contacts about 4 months ago you hear no click only the relays under the dash. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 13, 2014 Share Posted July 13, 2014 Got a test light or voltmeter handy? When it does it see if voltage is getting through the relay. And if voltage is getting to the starter solenoid. If the relay clicks its at least getting power because the same supply wire feeds both the coil and switch side of the relay. The two are spliced together not far from the relay. It may not be getting enough voltage though. Or the relay contacts could be erroded or pitted and not allowing sufficient current flow to engage the solenoid. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 14, 2014 Author Share Posted July 14, 2014 Well do you have the part number for the relay? It can't cost that much Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 14, 2014 Share Posted July 14, 2014 (edited) http://opposedforces.com/parts/info/82501AC030/ Looks like $23 list price. Online dealer pricing anywhere from $16-20. Still a chance it may not be the relay so I would recommend checking voltage at the relay when it acts up. Relay gets its power through the ignition switch "Start" contact. Poor contact there would cause the same problem. Edited July 14, 2014 by Fairtax4me Link to comment Share on other sites More sharing options...
Gloyale Posted July 14, 2014 Share Posted July 14, 2014 Still a chance it may not be the relay so I would recommend checking voltage at the relay when it acts up. Relay gets its power through the ignition switch "Start" contact. Poor contact there would cause the same problem. If the Ig. switch wasn't giving power thorugh it wouldn't click the relay.......power for the realy coil also comes from start signal, grounds through pedal. If the switch failed the coil would not see + so wouldn't click. this would be simple to solve with a testlight....or just like I said jumper Blue/red to the Red/yellow and turn the key......if it still doesn't work the relay isn't the issue. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 14, 2014 Share Posted July 14, 2014 Poor contact at the ignition switch doesn't necessarily mean NO contact. It only takes about 5 volts to make a relay coil click, but that's not nearly enough to make the starter solenoid click. I agree, quick and dirty test would be to jumper the wires together and should tell you right away if the relay is bad. Checking voltage in and out of the relay will tell you the same thing if there is a substantial difference in voltage. Low voltage going into the relay would suggest the ignition switch rather than the relay. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 14, 2014 Author Share Posted July 14, 2014 Well like right now it's ok should I wait until I have a no start issue? Or can I see the voltage difference without waiting for a no start? Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 14, 2014 Share Posted July 14, 2014 You can check it now but it would be better to wait until it happens again. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 16, 2014 Author Share Posted July 16, 2014 Ok happen again and I jumped it and it started fine.. plugged it back in and it also started fine.. Link to comment Share on other sites More sharing options...
