6 Star Posted July 12, 2014 Share Posted July 12, 2014 The time has finally come for the Ignition Lock to get stuck in my Brat. It was already in a state where the key could be removed in any position and while driving around. Currently it is stuck in the Run position, and can start the car, but will not turn back to shut the car off. Is it possible to remove this lock cylinder? I have a parts GL Brat with a good lock cylinder in it to swap out if so. 1985 Brat Gl (tilt column steering) Link to comment Share on other sites More sharing options...
Dinky26 Posted July 12, 2014 Share Posted July 12, 2014 As long as both columns are the same as in tilting you are good as gold. If they aren't both tilt you might be able to dismantle and pull the tumbler out and switch them. Link to comment Share on other sites More sharing options...
6 Star Posted July 12, 2014 Author Share Posted July 12, 2014 But how do I go about taking the cylinder out? On other cars I have removed a keeper screw and had to turn the key a certain way and then pull. But here there is nothing similar to that.I guess another way is just to swap columns? But that seems like a pain. Link to comment Share on other sites More sharing options...
jonas Posted July 13, 2014 Share Posted July 13, 2014 Looking head on at you're ignition switch. Remove the cover from the barrel. The piece with on/off/acc. stamped on it. easy to do, it's crimped on. At the 5 o'clock position, on the underside of the barrel should be a retaining pin or tiny screw. The hole may be covered up with a bit of solder but is easy to remove with a bit of digging. Once that is removed (pin/screw) you should be able to insert your key and slide it out. There may be a square plastic piece on the bottom of the barrel that you will need to slide out. pull it towards you. may also have a half circle plastic retaining ring as well. I'm just going from memory as it's been a few years since I've done this. Once you get the thing open it really becomes self explanatory. Good Luck! Link to comment Share on other sites More sharing options...
6 Star Posted July 13, 2014 Author Share Posted July 13, 2014 Sweet, I wasn't sure if that barrel cover came off or if it was a good idea to remove.Ill go mess with it now haha. Link to comment Share on other sites More sharing options...
6 Star Posted July 13, 2014 Author Share Posted July 13, 2014 It is a pin that holds the cylinder in, but it wont go in when I push on it. Does the cylinder have to be turned from the lock position for that pin to be able to retract? Or is it just being stubborn? The pin is flush with the cylinder, making it unable to be pulled out instead of pushing in. Link to comment Share on other sites More sharing options...
Dinky26 Posted July 13, 2014 Share Posted July 13, 2014 I pulled one apart earlier this summer, I don't remember exactly how it fell apart now. Seems like it just came apart when the screw was out. Must be just a pita for you. Link to comment Share on other sites More sharing options...
Hsoj Posted July 13, 2014 Share Posted July 13, 2014 Get a good bit of triflow in that lock first and wiggle that key around, it might just come out easier than you think. Compressed air might help free some stuff up too. Its easier to replace the whole lock assembly (the column lock and all) than get the cylinder out IMHO. Once you get the whole assembly out you might be able to fix it on the bench too. A good lock shop might be able to help with parts too. Link to comment Share on other sites More sharing options...
jonas Posted July 13, 2014 Share Posted July 13, 2014 I think what looks like the pin being flush is just a bit if solder or something holding the pin in. Try digging at it with something pointy. Once that is removed it should fall right out with a bit of wiggling. That's the way it was on my '85 Brat but I think it was a little screw, not a pin. Again it's been a few years. Link to comment Share on other sites More sharing options...
unibrook Posted July 13, 2014 Share Posted July 13, 2014 Our 1982 GL wagon 163k on her....starts with a paper clip. Or any key you might like to insert into her. She will take any tool to get her revving. She loves it. 1 Link to comment Share on other sites More sharing options...
SubaruPartsGirl Posted July 24, 2014 Share Posted July 24, 2014 (edited) I have a customer with a 1986 Subaru Brat 4WD w/tilt steering. I sold him an ignition lock and switch assembly, part number 783121210. The customer has received the part and has a tech trying to install it. I am being told that there are two missing wires on the new assembly and he believes that their purpose is for the chime. I can't seem to find any other applicable part for this model so I'm not sure if there is an issue with the part itself or possibly improper installation although his tech seems to be pretty familiar with the Brat. The part came as a very fresh and new assembly, didn't appear to have ever been handled or installed before. The customer is on the opposite coast of us so unfortunately it's not a situation where I can see it all layed out for myself. Have any of you experienced anything like this while installing new parts? If it helps, the tech said that the wires were blue and yellow. Edited July 24, 2014 by SubaruPartsGirl Link to comment Share on other sites More sharing options...
jonas Posted July 24, 2014 Share Posted July 24, 2014 Are those the missing wires? Link to comment Share on other sites More sharing options...
jonas Posted July 24, 2014 Share Posted July 24, 2014 if it's what I'm thinking of, they should be attached to a black plastic piece with a U shaped piece of copper in it. There is a cut out on the bottom of the barrel that it slides into Link to comment Share on other sites More sharing options...
SubaruPartsGirl Posted July 24, 2014 Share Posted July 24, 2014 Correct, blue and yellow wires on the old one assembly seem to be missing from the new assembly. Link to comment Share on other sites More sharing options...
jonas Posted July 24, 2014 Share Posted July 24, 2014 Those wouldn't come with the new assembly. Hope they still have the old ones, If not it won't affect anything. I never hooked mine ('85 Brat) back up as I find door chimes annoying. Link to comment Share on other sites More sharing options...
SubaruPartsGirl Posted July 25, 2014 Share Posted July 25, 2014 Thank you for your help! I'm thinking that the part may be incorrect somehow because he tech says that there is a small difference between the two parts that does not allow him to transfer these wires over. Link to comment Share on other sites More sharing options...
jonas Posted July 25, 2014 Share Posted July 25, 2014 Blue/yellow wired don't actually plug into the ignition except for the plastic bit sliding on the barrel cut out I mentioned. The other end hooks into a male/female connection under the dash, a little bigger around than a pencil. Wrong part is entirely possible as I've never heard of anyone coming across a NOS switch. his best bet is going to be a used one. There is an '83 wagon being parted out on this board that would work if the wagon has tilt collum. Link to comment Share on other sites More sharing options...
lrgvanman Posted January 7, 2019 Share Posted January 7, 2019 (edited) 783121070 comes up eventually as a no tilt complete assembly which is not the one what I need because I have the tilt. I got burglarized and the thief mucked up my ignition, and so, I am searching for the complete assembly, which the dealer says can be ordered with footnote; no tilt, handwritten. Dead-end there. UPDATE: Changing the lock cylinder sounds the best option now. Anyone have a cylinder number? I found 783131010 at SubaruParts.com and I'd really like to verify that number. UPDATE: Glad I checked again, that latter number, 783131010, shows the switch, not the lock cylinder! Thanks and have a great day all! Edited January 8, 2019 by lrgvanman Link to comment Share on other sites More sharing options...
lrgvanman Posted January 7, 2019 Share Posted January 7, 2019 I am gonna try this:https://www.ebay.com/itm/Subaru-ignition-lock-cylinder-X6-short/302185124450?fits=Year%3A1984|Make%3ASubaru&hash=item465ba31262:g:TjAAAOxynapRhdL1:rk:16:pf:0#vi-ilComp Link to comment Share on other sites More sharing options...
lrgvanman Posted January 8, 2019 Share Posted January 8, 2019 I attempted to buy; https://www.ebay.com/itm/Subaru-ignition-lock-cylinder-X6-long/302432735361?fits=Year%3A1984|Make%3ASubaru&hash=item466a655081:g:6KoAAMXQoiJRhgtN:rk:17:pf:0 and I encountered a message saying; "The seller can't accept payments right now". Looking some more tomorrow. Link to comment Share on other sites More sharing options...
pawn_that_dude Posted March 17, 2019 Share Posted March 17, 2019 I have the same problem I think (84 GL). Cylinder is stuck in the run position and can't be turned either way. The key initially was stuck, but I eventually just yanked it out after I tried every way to move it. I partially took apart the lock cylinder to see how it works. Does anyone have any tips for how I could just disable the lock entirely so I could just turn it with any old key? I don't really care that much about the security (well, currently the security is none because you can bump start it anytime you want). Link to comment Share on other sites More sharing options...
SpecialEd Posted April 10, 2019 Share Posted April 10, 2019 I wanted to say thanks for this thread. I just had to go thru transferring lock cylinders. One was secured with the screw the other had the solder (JB weld?). I found that it was pretty easy to disassemble. Disconnect your Battery! Then after removing the plastic housing, remove the outer crimped ring with your ignition setting stamped on it. (lock, ac, start, ect...) I used a flathead screwdriver and pried at the seam a little bit. Starting near front side then finishing on the rear side after I got a little bit of it loose. Next if you have a lock screw holding the cylinder in place remove that or scrap away all the solder gunk holding the cylinder in place. At this point the lock cylinder can slide out and be swapped. So here is where I found the interesting things out. For those who might not have the swap options. The housing with the wires soldered to it on the left side is what you ignition lock cylindr is turning. You can manually turn this with a screwdriver and achieve all ignition settings. You might have to be clever in how you mount and turn this part but there you go. That is how to bypass the Lock mechanism and start the car. IMPORTANT: Your Steering Wheel can still LOCK UP. If you look in between the Lock Cylinder and the other half that actually turns the settings you will see the steering wheel lock mechanism that engages when you turn the wheel so many degrees and the lock cylinder isn't there to let it stay unlocked I saw a video where someone took a drill gun and just bored this part out. For those wanting to remove your stuck key and try to get it all working again. You will see a gap in the lock cylinder exposing the tumblers. Press the tumblers down as you wiggle the key and pray for some luck. Once your key is unstuck spray it all liberally with graphite dust, keep working it until you can operate it somewhat normally and reassemble it all. GL. The link for the x6 short looked like my cylinder. I also got an error trying to purchase one. I pulled the other cylinder from my donor car. Originally the soldering had me thinking that was a hopeless cause. Since I wasn't worried about breaking any of the housing I wasn't very gentle scraping away the solder. It took some doing but I finally managed to pry/chip it off and remove the cylinder. I'm not sure if it was that glued up from the factory or maybe it already had been replaced before. Whatever the case persistence paid off. Don't blame me if it doesn't work out. I'm a newbie at this stuff but from my short experience that is how the system seems to work. Special thanks to Jonas for all your input. I would have been lost without you. Link to comment Share on other sites More sharing options...
Subi81 Posted March 2, 2024 Share Posted March 2, 2024 Had the same issue on my 81 wagon = key stuck in the ON position. I had to drill the pin out at 5 o'clock on my 81 wagon then the cylinder pulled out (was still in the ON position) towards the key mine took some force. Be careful the lock rod and pivot pin are not retained and will go flying, ask me how I know. Link to comment Share on other sites More sharing options...
RandoManufacturing Posted March 6, 2024 Share Posted March 6, 2024 Hello all. I know this is an old thread but I figured out a replacement lock cylinder for my 87 Brat. I checked all of the parts stores I could get to here in Detroit and could not find a replacement. I found that Standard Motor Products PART# US170L has the same body. It is for a 1982 -1986 Nissan Sentra. The only change is that the tumbler body is a little longer on the back but can be trimmed down to work. I would upload a picture but can't seem to get that to work. I hope this helps somebody. Link to comment Share on other sites More sharing options...
Subi81 Posted March 10, 2024 Share Posted March 10, 2024 (edited) Fixed my ignition lock. I found that the C-16-106 lock style was an identical replacement except for the tumblers. Original Subaru tumblers are thicker, but the tumbler kit I found on ebay worked for the C-16-106 cylinder and mine needed to be replaced. A C-16-123 might work for this year, there is an extended tang on the rear of the lock but this could be ground off or might not be a problem since the tang protrudes into the steering lock eccentric, tumblers appeared to be the thin style I recommend the C-16-106 though. I did have to do some slight sanding/filing/stoneing of the tumblers to get the lock to operate without dragging, your mileage may vary, I am no locksmith. Several of the original tumblers had groves worn in them from years of use which is probably why the original key stopped working 100k ago. The pivot lever lock portion had worn a groove in the cylinder, I don't think this was causing any issues. A ridiculously thin portion of the cylinder that sets how far the key is inserted was completely missing this could allow the key to miss-possition, i.e. to deep or to shallow and prevent the lock from turning. Edited March 10, 2024 by Subi81 Spelling Link to comment Share on other sites More sharing options...
