Rooster2 Posted July 13, 2014 Share Posted July 13, 2014 I bought a replacement fuel tank filler neck for my 99 OBW. I haven't installed it yet. but will soon.I patched it once, but motor started hesitating and bogging down, particularly when engine is cold. That started happening when the CEL came on. Code read out indiacates evaporative fuel system problem. My question.........does the leak in the filler neck cause the driveability problems?? Thanks for any replies. Link to comment Share on other sites More sharing options...
heartless Posted July 14, 2014 Share Posted July 14, 2014 ...motor started hesitating and bogging down, particularly when engine is cold. just out of curiousity, is it also damp/humid when you are having the problem? my 95 has a similar issue when very damp out (high humidity) & engine is still "cold" - mine tends to throw a misfire code, tho. I thought I had a leak in the filler neck, but it turns out it is in the tank itself, near the filler neck connection. either way, it is drawing moisture into the system thru the leak point. Once up to full operating temp it runs fine, but that first few minutes can be rough... Link to comment Share on other sites More sharing options...
Rooster2 Posted July 14, 2014 Author Share Posted July 14, 2014 damp humid condition doesn't seem to make any difference. My thought is to replace the filler neck, clear the CEL code, and see how the motor runs. If still acting up, then change the plug wires, and perhaps the spark plugs. Link to comment Share on other sites More sharing options...
heartless Posted July 15, 2014 Share Posted July 15, 2014 (edited) sounds like a plan. You may want to soak all the bolts/screws ahead of time with a good penetrating oil - mine had three screws at the cap and 2 small bolts down along the filler tube. all but one of the upper screws came out ok after soaking with PB Blaster. the one screw twisted off - had to hunt down a replacement for it - fairly common one on a Subaru tho, so it wasnt hard. make sure you keep track of where the evap/vent tubing goes - mine being older only had one tube (vent) so it was very easy. Edited July 15, 2014 by heartless Link to comment Share on other sites More sharing options...
Rooster2 Posted July 15, 2014 Author Share Posted July 15, 2014 sounds like a plan. You may want to soak all the bolts/screws ahead of time with a good penetrating oil - mine had three screws at the cap and 2 small bolts down along the filler tube. all but one of the upper screws came out ok after soaking with PB Blaster. the one screw twisted off - had to hunt down a replacement for it - fairly common one on a Subaru tho, so it wasnt hard. make sure you keep track of where the evap/vent tubing goes - mine being older only had one tube (vent) so it was very easy. Thanks for the advise, I appreciate it. Rooster2 Link to comment Share on other sites More sharing options...
