N8NQU Posted May 11, 2004 Share Posted May 11, 2004 i just turned 60K on it and the EGR LIGHT came on,i know it's programed to do that.how can i RESET IT?????thanks,Bill. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted May 11, 2004 Share Posted May 11, 2004 Remove the drivers side kick panel (afew plastic screws) Under there should be some green and I think.... blue? connectors. There should be 3 of them total. 2 are plugged in and 1 is loose. Basically you unplug the 2 and plug whichever end fits into the one that was previously loose. Example... blue and green are together. unplug and if the greens mate up, plug them in and leave the blue loose. Link to comment Share on other sites More sharing options...
N8NQU Posted May 11, 2004 Author Share Posted May 11, 2004 Thanks,i'll give it a try and i'll you know.Bill. Link to comment Share on other sites More sharing options...
subiemech85 Posted May 12, 2004 Share Posted May 12, 2004 think of it as your check and inspect t-belt reminder warning light for those of us that did away with the egr what 87 said above^ Link to comment Share on other sites More sharing options...
N8NQU Posted May 13, 2004 Author Share Posted May 13, 2004 the T-Belts where replaced at 57K.I do like your reminder of the egr light to check the belts.Bill. Link to comment Share on other sites More sharing options...
N8NQU Posted May 18, 2004 Author Share Posted May 18, 2004 i took the kick panel off and droped the fuse box,then i found the connectors,switched them and it worked NO EGR LIGHT.so i guess i'll wait now untill it has 120K so the light will come on again.thanks for the info.Bill. Link to comment Share on other sites More sharing options...
newsance Posted May 18, 2004 Share Posted May 18, 2004 SO there is some diagnostic light that comes on every 60k miles regarding EGR? What exactly is it telling you to check about EGR? Every other car I have owned has been jsut about maintenance free with that. Link to comment Share on other sites More sharing options...
subiemech85 Posted May 18, 2004 Share Posted May 18, 2004 it is just a light that comes on every 60,000 miles! what you do with it is up to you as far as how much service, check your "maintenance schedule" Link to comment Share on other sites More sharing options...
