thekauz Posted July 15, 2014 Share Posted July 15, 2014 I have a 91 loyale with an A/C problem. I was charging the A/C system with R12 and when the A/C was turned on it would run for 10 seconds and then the clutch shutoff off. When I would turned the system off and back on it would work for 10 seconds and the clutch would cut out again. Following an earlier thread I found on this forum I jumpered the belt protection system. The A/C clutch engaged and said engaged. temp out of the A/C was 57 degrees F. My question: Is it OK to leave the system running like this? Also is the pulser bad? Is it turning off the clutch? Is their a test for the pulser? Link to comment Share on other sites More sharing options...
djcommie Posted July 15, 2014 Share Posted July 15, 2014 What does your gauge manifold say for low and high pressures? Did you fill a system that was vacuumed, purged, and with the receiver replaced? 1 Link to comment Share on other sites More sharing options...
thekauz Posted July 18, 2014 Author Share Posted July 18, 2014 Its an all original equipment system and no it was not vacuumed and purged. I hace read on other threads is ok to run the system jumpered to bypass the belt protection system. Car seems to run fine. I guess I need to figure out why the A/C compressed turns off after it run for 10 seconds. is there a test procedure for the pulser that usually causes that problem?? Link to comment Share on other sites More sharing options...
djcommie Posted July 23, 2014 Share Posted July 23, 2014 Without the correct tools, you're going to destroy the system. An empty system absolutely requires a new receiver/dryer. Water combines with R12 oil and creates acid, corroding the lines and eventually destroying the TXV and compressor. I don't know how the pulser system works, but I imagine your compressor stops because the low side pressure drops too low and trips the low-pressure cutoff switch. R12 is expensive, R134 is less efficient and requires every o-ring to be changed to HNBR, and R152 isn't type accepted in automotive applications (is slightly flammable). Without an understanding of how phase change refrigeration works, a mistake can permanently damage the system or you can injure yourself. Link to comment Share on other sites More sharing options...
idosubaru Posted July 23, 2014 Share Posted July 23, 2014 (edited) I may be charged too low or too high. What are the pressures? I would not jumper an A/C system to get it to run. I always replace orings and charge Subaru's without vacuuming or replacing anything. Subaru's routinely go 100,000 miles without issues. Subaru A/C systems are robust and rarely have issues. I never replace receiver/dryers in Subarus, though they're inexpensive so why not on one that's so old? While things can happen, and they may be more common in other manufacturers systems - they very rarely happen in Subaru's. Here's my write up with 14 pages of other people that have done the same over the years: http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html So far not one person has come back to say they're A/C exhibited issues. Same here, I've never seen a failure after I've worked on a Subaru a/c system. I ***would not*** apply this approach to other less-robust systems on other manufacturers vehicles. I totally understand people who are scared or uber-technical and that has it's place. But realistically speaking there are plenty of people that appreciate an approach that's inexpensive and has a high percentage of success. All that being said - it needs properly diagnosed. what was the original issue? If the pressures end up not being the problem then look into 1. relays in the system 2. the a/c compressor clutch Edited July 23, 2014 by grossgary Link to comment Share on other sites More sharing options...
