FlyBoy83 Posted July 15, 2014 Share Posted July 15, 2014 working on a 94 Legacy L that came from factory w/o Cruise control an aftermarket cruise control was added by a subaru dealer back in like 97ish. the cruise control quit functioning. I was looking at similar year models and it doesn't look too hard to "transplant" the cruise control from on that has a factory install. the question is "do all the OEM ECU's contain the capability to operate the Cruise control or do I need to swap the ECU? Link to comment Share on other sites More sharing options...
Gloyale Posted July 15, 2014 Share Posted July 15, 2014 Factory cruise control is operated by a seperate computer. to transplant you would need from donor -Cruise computer and connector w/ wires -Vacuum pump from underhood...passenger side low on the framerail -Clutch switch if manual -4 pole brake switch (DPST) -"cruise" on button -Vacuum actuated throttle cable Link to comment Share on other sites More sharing options...
