Subaru EA-82 OEM Part Numbers
Hello!
This list was compiled during my recent EA-82 Carburated engine rebuild. Hope someone finds it of use.
These are OEM part numbers for EA-82 engines:
Cam Tower to Head Metal Reinforced O-Ring 13089AA010
Cam Tower Retainer O-Ring 806958020
Cam Tower Shaft Oil Seal 806738040
Cam Tower Oil Relief Spring 15020AA011
Front Main Seal 806738070
Rear Main Seal 806776011
Oil Pump "Mickey" Oil Seal 15066AA000
Oil Pump Shaft Oil Seal 806718090
Oil Pump O-Ring 806945020
Oil Pan Cork Gasket 11121AA001
Water Pump O-Ring 806927010
Gasket - Water Pump 21114AA000
Gasket - Intake Manifold to Head 14035AA150
Gasket - Exhaust Manifold to Head 44022GA330
Gasket - Thermostat Gasket 11072AA030
RH (Passenger Side) Rubber Valve Cover Gasket 13270AA001
LH (Driver Side) Rubber Valve Cover Gasket 13272AA001
Throwout Bearing Clip 30539AA000
PCV Valve 11810AA000
Oil Cap 15255AA002
Head Bolt - Long 800211050
Head Bolt - Short 800211060
Head Bolt Washer 803011070
Exhaust Manifold Stud 800910290
Exhaust Manifold Nut 902170018
Intake Manifold Bolt - Long 800108790
Intake Manifold Bolt - Short 800108800
Enjoy! :)
Edited by BirdMobile
  • Like 5
