Gwywnc Posted July 19, 2014 Share Posted July 19, 2014 Hi, and now another problem So when I drive and brake there is a "clunk" sound that can be heard and felt, it will do it once but not again until you drive for a while. When I push the brakes slowly it doesn't happen but when I break like normal it will happen... Any ideas? Thanks Link to comment Share on other sites More sharing options...
naru Posted July 19, 2014 Share Posted July 19, 2014 (edited) Most likely front brake pads w/slightly excessive fore and aft clearance. Will it clunk again right away w/going in reverse and applying the brakes briskly? If this is what it is.it is not a safety problem,just annoying. Edited July 19, 2014 by naru Link to comment Share on other sites More sharing options...
Gwywnc Posted July 19, 2014 Author Share Posted July 19, 2014 I'm not sure if it will do it in reverse, just started today, what ever is happening it sounds like somthing is hitting the bottom of the floor board. Link to comment Share on other sites More sharing options...
naru Posted July 19, 2014 Share Posted July 19, 2014 Probably something different then. Loose pads will clunk from day 1. Link to comment Share on other sites More sharing options...
