lacking on top-end
well ive really noticed that my car really kind lacks on the top end, like once i hit 45mph it doesn't really pull hard, it will go on a flat part from 60 to 70 in like 5 seconds, but i dunno, hills are my worst enemy.
what could i do to help, help the engine breath better by better exhaust, 1 7/8's inch from the heads to a 2inch Y-pipe, to a cherrybomb to a 2 1/4inch tip. since my cat is rusted through badly i need exhaust anyways.
also port the intake, since i am rebuilding the hitachi soon also.
anything else you can think of??
timing was mentioned
vacum leak
weak coil
crappy wires
rusty cat? umm maybe plugged as well that will kill top end
plugged airfilter
the fact you are rebuilding the hicrappy i would think maybe its leaning out?
i dunno bout the hitachi's don't they have a secondary type thing? maybe its not opening?
northguy, how old were your girlfriends? :grin: :grin: give them time! jk
scooby, I would do a larger exh, bottom end may be sacrificed a tad, but top end should benefit pretty well. A good intake is a must too...use mandrel bends wherever you can
