AT Vacuum line
What port should the AT vacuum line be tapped from? It shifts from 1st almost instantly to 3rd (and bogs down of course) and does not kickdown even though the kickdown solenoid appears to be working electrically. Modulator has been replaced and governor seems to work. I hate to drop the trans pan if I don't have to.
Swapped governors and modulator and still the same thing. I am planning to drop the pan and see if there is something stuck in the pickup tube if vacuum doesn't work.  What's the best spray cleaner to use on transmission components?
