opus Posted July 26, 2014 Share Posted July 26, 2014 Doesnt work, under hood is mega crowded with it, I want it gone. Ok to pull the compressor and hoses? I can only see 1 bolt holding compressor bracket on...has to be more than that? Matter of fact, I want to yard out whatever I can under the hood. What are my options? Link to comment Share on other sites More sharing options...
BirdMobile Posted July 26, 2014 Share Posted July 26, 2014 My '87 is not a turbo, but the bracket is the same. I yanked the AC compressor, took a length of 1" aluminum rod stock and cut it to length to fit where the compressor was, drilled and tapped it 3/8-16 on both ends, and bolted it in as a support pillar where the compressor used to be. You could also use a piece of pipe cut to length and a LOOONGGG 3/8" bolt and nut. You will need a different length inner V-Belt if the compressor pulley is gone, I used a NAPA Premium XL belt, size 9345. The longer outer belt that runs the alternator doesn't need to be changed, only tensioned tighter. Link to comment Share on other sites More sharing options...
opus Posted July 26, 2014 Author Share Posted July 26, 2014 What must I replace? Is there more to pulling the compressor? I looked but cant see a whole lot til I start pulling things. Link to comment Share on other sites More sharing options...
BirdMobile Posted July 27, 2014 Share Posted July 27, 2014 The compressor supports the bracket that holds the alternator on. It will have a "hollow spot" underneath when the compressor is gone, and an unsupported overhanging section at the left where the "pillar" I wrote about needs to go. Link to comment Share on other sites More sharing options...
opus Posted July 27, 2014 Author Share Posted July 27, 2014 Got it. Link to comment Share on other sites More sharing options...
BirdMobile Posted July 27, 2014 Share Posted July 27, 2014 Photo of AC Compressor delete, with support pillar: 1 Link to comment Share on other sites More sharing options...
opus Posted July 27, 2014 Author Share Posted July 27, 2014 Pictures, yes! So I'll pull the alternator and that one bolt and the compressor comes off....apparently. You know, I have a spare ea82 [no AC] in the shed. If it has alternator bracket on it I could use it. Link to comment Share on other sites More sharing options...
BirdMobile Posted July 27, 2014 Share Posted July 27, 2014 As I recall, there are 3 or 4 bolts holding the AC compressor to the engine. Link to comment Share on other sites More sharing options...
wagonist Posted July 27, 2014 Share Posted July 27, 2014 It depends on who installed the A/C. Dealer fit sometimes have different brackets to those which were factory fitted (it's really random what you get over here). The non-A/C cars have different brackets for both the power steer pump & alternator (which is moved over a bit) There is another bracket underneath the A/C compressor. You'll need to remove the alternator to see it. 3 bolts holding that on. 1 behind the tensioner arm, 1 down between the A/C compressor & power steer pump. They are both horizontal & you'll need to find them by feel or a mirror. The right side one needs to come out fully, the left side only needs to be loosened so the assembly lifts off. If you can't find the 3rd one, then you need to find another hobby Unless you want to find & change the brackets, then you're going to have to make up a dummy compressor Link to comment Share on other sites More sharing options...
scoobiedubie Posted July 29, 2014 Share Posted July 29, 2014 (edited) The a/c compressor runs year round. In the winter, it helps suck the moisture out of the air so than dry warm air is blown onto the windshield in the defrost mode. If no compressor, then you are blowing warm moist air onto the windshield and the defrost has essentially been crippled. Edited July 29, 2014 by scoobiedubie Link to comment Share on other sites More sharing options...
opus Posted July 29, 2014 Author Share Posted July 29, 2014 How did I ever get by without A/C for the past 40 years? 2 Link to comment Share on other sites More sharing options...
BirdMobile Posted July 29, 2014 Share Posted July 29, 2014 On 7/29/2014 at 4:02 AM, opus said: How did I ever get by without A/C for the past 40 years? Yeah... I don't have much use for it either... and I even live in the desert! Link to comment Share on other sites More sharing options...
opus Posted July 29, 2014 Author Share Posted July 29, 2014 I found an alternator bracket of a spare EA82, so I'm good to go. Link to comment Share on other sites More sharing options...
scoobiedubie Posted July 29, 2014 Share Posted July 29, 2014 On 7/29/2014 at 4:28 AM, BirdMobile said: Yeah... I don't have much use for it either... and I even live in the desert! Low humidity. Link to comment Share on other sites More sharing options...
