MR_Loyale Posted July 26, 2014 Share Posted July 26, 2014 I am close to starting up my EA82 that has been apart for head work and such. It occurred to me that just filling the radiator with coolant would leave the engine sucking air for a while until it circulates. Is there a ways to ensure there is coolant in the block immediately upon first startup? Add via thermostat housing perhaps? Or am I making an issue out of nothing? Link to comment Share on other sites More sharing options...
Ibreakstuff Posted July 27, 2014 Share Posted July 27, 2014 You could turn the water pump by hand and milk the lower coolant hose. But my belief is that most of the air would burp out before you reach any temps that could hurt anything. Link to comment Share on other sites More sharing options...
johnceggleston Posted July 27, 2014 Share Posted July 27, 2014 oil is a much bigger concern than coolant. spin the engine over with the starter while the injectors are unplugged. this will circulate the oil and keep it from starting. the t-stat will not open until the engine reaches full temp. so even if there is coolant in the block it will not be circulating. once at operating temp the t-stat will open and coolant will flow. top it off as needed. Link to comment Share on other sites More sharing options...
