Looking for engine and tranny xmember spacer from an outback
I haven't had much luck in any other forums so I figured I would try here. I would like to buy the 1.1/4" spacers from the engine and transmission crossmembers on a 95-99 outback. I will pay to have someone take them off a parts car or wrecker.
Spacers on the trans cross member are welded on so you need the whole thing, plus bolts.
You will also need the transverse bushings for the front control arms.
No they aren't.  the paint sticks them toghether.
they wack off with a hammer.
You don't need the LCA's with EA lift.  that's if lifting form Leg/Imp to FOR/OBK stuff.
Edited by Gloyale
The last ones I saw definitely had a couple tack welds. Maybe that was someone's approach to make them stay put during removal/install of the crossmember.
I wasnt aware the OB cross member spacers were commonly used with EA lifts.
Hockey pucks are cheap and easy to drill through.
