TheLoyale Posted July 30, 2014 Share Posted July 30, 2014 Alright, so I am going to remove a couple unneeded things on the old Hitachi ('83 Coupe to be exact) but I do need some photos of their locations as I forgot whats what. Done some searching and I did pull up GDs old Hitachi thread, but the photo links have been broken, so no images to go with all the text. Here are the 3 things I am looking for. Anti-Afterburn Valve Thermo Vacuum Valve Metering Port Vacuum Control Valves If someone could post a photo that would really be tops! Thanks, -Tom Link to comment Share on other sites More sharing options...
ferox Posted July 30, 2014 Share Posted July 30, 2014 I don't have pictures of the things you mention but I do have labeled pictures of an '83 Hitachi with the things you need to keep from another thread. You can do some process of elimination. 1 Link to comment Share on other sites More sharing options...
TheLoyale Posted July 30, 2014 Author Share Posted July 30, 2014 Simplified Hitachi is beautiful! Link to comment Share on other sites More sharing options...
TheLoyale Posted July 30, 2014 Author Share Posted July 30, 2014 Alrighty, so here are some pictures from mine. Can someone please tell me what these items are. This one has two vac lines running two it and is on the driver side of the air filter. This one is under the air filter and next to the Thermostat housing pretty much under the throttle cable plate. This is on the passenger side and ties into the the header block, in-fact there are two of these, the other is on the driver side. I know its for emissions, but forgot what this is called. This one is above the thermostat housing on the passenger side, it has two vac lines that run to it. This is on the driver side and one of the vac lines runs to the Carb and the other runs to another unit under this one. I think these may be the Metered port control valves as they bolt to the intake, and both feed other components. Am I right? Both of these are on the passenger side firewall. And lastly, this is on the driver side closest to the valve cover. Help with any of this will be indeed wonderful! I am trying to make the Hitachi as simple as possible by following GDs old post, but the photo links are dead so I have no idea what is what. -Tom Link to comment Share on other sites More sharing options...
TheLoyale Posted July 31, 2014 Author Share Posted July 31, 2014 Thank you Ferox for posting these photos, they do really help decipher what is not needed on the carb. I've removed a few things so far as you can see below, I will need to get some Vacuum caps since I can't find the ones I had lol. I will also be using some Expansion plugs for the larger ports (Like in the Air Filter housing ect) So these must be the Metering Port Vacuum Control Valves And here are I believe to be the Anti-Afterburn Valves with plumbing and silencers? So far I think I'm headed in the right direction. Link to comment Share on other sites More sharing options...
Sapper 157 Posted May 22, 2015 Share Posted May 22, 2015 Hey I know this thread has been inactive for about a year but I was curious if you noticed any change of behavior when you did these deletes. 1 Link to comment Share on other sites More sharing options...
TheLoyale Posted May 22, 2015 Author Share Posted May 22, 2015 By removing all of the emissions items, including the canister and all vac lines that aren't needed. It has really improved the engine. Runs smoother and has a little more getty up. It really makes this old Hitachi shine! Link to comment Share on other sites More sharing options...
TheLoyale Posted May 22, 2015 Author Share Posted May 22, 2015 Here is a complete post with updated photos of a 100% de-smogged EA81 Hitachi. http://www.ultimatesubaru.org/forum/topic/147986-my-83-gl-coupe-hardtop-sss/?p=1280249 Link to comment Share on other sites More sharing options...
Sapper 157 Posted May 22, 2015 Share Posted May 22, 2015 Good gracious, that Hitachi is beautiful! Thanks man! I really appreciate the pics and the mini writeup you've done here! 1 Link to comment Share on other sites More sharing options...
