Greg106 Posted July 30, 2014 Share Posted July 30, 2014 I'm starting a thread about an issue I'm having and to see what suggestions anyone might have. We just swapped over the engine in a 2005 Saabaru 92x aero. The original engine was a ej205. The replacement engine is a reman ej255 long block unit from ATk for a 2005 wrx application.. We swapped over all of the components from the old engine with some minor modifications. We are using the ej255 heads and blocked off the cam sensor holes and avcs holes as we are not utilizing that system. We relocated the cam sensor back into the original location on the driver side head with an aftermarket bracket. The problem we are having now is that we have a no spark condition. We are getting an injection pulse and also a pulse to the ignition coil but no spark. Not sure of what amount of voltage I should be getting for a signal. We verified power and ground to coils. We verified on the back of the cam gear that the trigger points are identical to the old 2.0l cam gear amount of teeth etc. We verified that the crank gear also looked the same and had the same amount of teeth. Factory part numbers are the same for the crank gear for the two engines. We also checked timing belt marks verified everything lined up properly. I'm kind of at a loss here now any suggestions would be greatly appreciated. Link to comment Share on other sites More sharing options...
zombieforce Posted July 30, 2014 Share Posted July 30, 2014 Check the fuse for the ignition coil. Link to comment Share on other sites More sharing options...
idosubaru Posted July 30, 2014 Share Posted July 30, 2014 you're using the EJ205 manifold? which coil are you using - it's good? Link to comment Share on other sites More sharing options...
Greg106 Posted July 31, 2014 Author Share Posted July 31, 2014 We are using all of the original ej205 components,electronics etc vehicle ran ok before swap just had a bad rod knock. We do have power and ground to coils and also are getting a signal to coil but not sure if it is correct in voltage or frequency. Wondering if anyone else has done a similar swap and had this issue or is familiar with possible differences in cam or crank gears that may cause this issue. Link to comment Share on other sites More sharing options...
idosubaru Posted August 12, 2014 Share Posted August 12, 2014 i would triple check those cam/crank gears. you can check as well but calling subaru, using an online vendor, or ebay or using opposedforces website to verify part numbers and see if they're positively identical. the 2005 originally has AVCS right? Link to comment Share on other sites More sharing options...
Greg106 Posted August 12, 2014 Author Share Posted August 12, 2014 The original ej20 did not have avcs the new engine does but we are not utilizing it. We are using all of the original engine components on the new long block. We are using a bracket to locate the cam sensor in the original location we verified that the two trigger points on the back of the drivers side intake cam sprocket are identical to the original sprocket.Crank gear part numbers are identical between engines. Timing marks are all lined up the belt was pre installed. this is a ATK reman longblock. Also we do have an injection pulse. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 12, 2014 Share Posted August 12, 2014 If you're getting a signal to the coils you should be getting spark. Did you remove a coil and stick a spark plug in the end to verify you have no spark? Remember to ground the plug on the block. Are you using the proper spark plugs? Link to comment Share on other sites More sharing options...
Greg106 Posted August 13, 2014 Author Share Posted August 13, 2014 We are using the proper plugs and testing it properly. The fact that we are not getting spark and have a signal is what is confusing us. We have even swapped coils to eliminate possibly a bad coil. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 13, 2014 Share Posted August 13, 2014 Does it have individual coils on the plug or is it a coil pack with plug wires? Link to comment Share on other sites More sharing options...
Greg106 Posted August 13, 2014 Author Share Posted August 13, 2014 Individual cop Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 13, 2014 Share Posted August 13, 2014 is there a good ground from the engine? the plugs still need that return path. or maybe a CPS problem? Link to comment Share on other sites More sharing options...
Dirtrider Posted February 20, 2024 Share Posted February 20, 2024 Did you ever find out what was up, I just swapped my engine for the same reasons now no spark Link to comment Share on other sites More sharing options...
