Ranfis Posted July 31, 2014 Share Posted July 31, 2014 I have a 1998 outback with a bad automatic transmission # TZ102Z2DBA AWD, sombody offer me a tranny from a 1999 forester AWD # TZ1A3ZC2AA-P8 I see some diferences on the tranny's like the one for the forester has a filter on the side is this just and upgrade or is it tottaly different wil it fit the outback please help this is my first Subaru I have never been even close to one but I;m learning quick. Link to comment Share on other sites More sharing options...
johnceggleston Posted July 31, 2014 Share Posted July 31, 2014 (edited) not a match. it will not work. do not buy it. you can use any auto trans from the following : 96 - 98 outback, 98 forester 96 - 98 GT 96 - 97 LSi in that order. if you use the GT or LSi your speedo will be a bit off. you can NOT use any auto trans from an ej22 car. Edited July 31, 2014 by johnceggleston 1 Link to comment Share on other sites More sharing options...
Ranfis Posted July 31, 2014 Author Share Posted July 31, 2014 thank you very much for the great advise I will start looking for one that fits, it is or was a good running car only 88K miles, do you know of a good source that won't rip you off selling you junk either in VA or MD in the meantime I will be selling or trading the TZ1A3ZC2AA-P8 Link to comment Share on other sites More sharing options...
gregB Posted July 31, 2014 Share Posted July 31, 2014 Bad at 88,000. Trans are usually robust, and go high miles. What is wrong with it, what is it acting like?. Link to comment Share on other sites More sharing options...
Ranfis Posted August 1, 2014 Author Share Posted August 1, 2014 the car wont moove when I put it in drive or reverse but I can hear grinding in the right side I replaced the r/s cv axle because the old one had pulled apart from the inner axle, since I'm new to Subies is the differential in front of the tranny or is it one piece. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 1, 2014 Share Posted August 1, 2014 (edited) the diff is in the front of the trans. in the auto trans it is a 2 piece set up, bolted together to look like one piece. actually it is a three piece trans with the rear most section controlling / sending power to the rear. the car wont moove when I put it in drive or reverse but I can hear grinding in the right side before you swap the trans , jack up the left front wheel, start the car and put it in D (HAND BRAKE ON) if the wheel turns it may be your right front axle that is bad. (but there would also have to be a failure with the transfer clutch sending power to the rear.) but still worth a check. power to the rear and power to the front are two different issues. but if there is no power to the rear, and you have a right front axle failure, you are not going any where. the diffs do not fail often, and usually only if they run out of gear oil. do you have a FWD light on the dash? did the rear wheels ''drive'' the car before the grinding. how long have you had the car? how long have you had the car? how well didi it run before this became problem. Edited August 1, 2014 by johnceggleston Link to comment Share on other sites More sharing options...
Ranfis Posted August 1, 2014 Author Share Posted August 1, 2014 unfurtunately I bought it at an auction in DC and didn't checked til I had bought it so I dont know much about the little wagon I do know that the sway bar was disconnected and for the looks on the fender inner skirt the tire had been rubbing against it and the r/s cv was disconected from the side next to the differential Link to comment Share on other sites More sharing options...
Ranfis Posted August 1, 2014 Author Share Posted August 1, 2014 do you think for the sound of it could it be the differential Link to comment Share on other sites More sharing options...
johnceggleston Posted August 1, 2014 Share Posted August 1, 2014 the r/s cv was disconected from the side next to the differential if this is still the case, i would start here. a disconnected axle will eliminate power to the wheels, front in this case, if you have an open differential. replace / reconnect the axle. then you should have power to the front. next, power to the rear. keep at it. Link to comment Share on other sites More sharing options...
mohrtek Posted August 19, 2014 Share Posted August 19, 2014 Hello I have a 2004 Forester XT throwing a CEL code "Shift Solenoid D" as well as the AT Oil Temp light blinking. Its causing me to get stuck in 1st gear off and on. Problem is, the transmission is apparently not from my year car. No one told me this when I bought it. Several mechanics cannot figure out what year its from, and most are afraid to drop to pan to look at the valve body if they dont know what year the trans is from. I tried replacing valve body from 2nd generation stock XT trans and it doesnt fit. 2 questions: 1. Does someone know how to identify which year/model transmission I have? 2. What year transmissions will fit if I have to replace the whole thing? 3. Where to get a decent used trans that will fit? Thanks Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 20, 2014 Share Posted August 20, 2014 '04 was a year of change for the 4EAT, could be the month of manufacture is important to figure out what should be in there. Try going to www.car-part.com and look for a trans for your car and see if it asks for the month, and if it comes up wiuth different parts for late/early in the model year. 1 Link to comment Share on other sites More sharing options...
johnceggleston Posted August 20, 2014 Share Posted August 20, 2014 (edited) 1. Does someone know how to identify which year/model transmission I have? 2. What year transmissions will fit if I have to replace the whole thing? 3. Where to get a decent used trans that will fit? 1. what is the trans ID# on the bell housing at the starter ? TZ1A3ZC4AA ??? 2. 00 - 03 or 04 probably 3. car-part.com Edited August 20, 2014 by johnceggleston Link to comment Share on other sites More sharing options...
mohrtek Posted August 21, 2014 Share Posted August 21, 2014 '04 was a year of change for the 4EAT, could be the month of manufacture is important to figure out what should be in there. Try going to www.car-part.com and look for a trans for your car and see if it asks for the month, and if it comes up wiuth different parts for late/early in the model year. Thanks. I went to car-part.com but it comes back with "Non-Interchange search using Subaru XT and similar" with no results. No month is asked. Link to comment Share on other sites More sharing options...
mohrtek Posted August 21, 2014 Share Posted August 21, 2014 1. what is the trans ID# on the bell housing at the starter ? TZ1A3ZC4AA ??? 2. 00 - 03 or 04 probably 3. car-part.com I have not looked @ the bell housing near the starter for that code but I will do that ASAP. Will have to figure out where the starter is first . Thanks. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 21, 2014 Share Posted August 21, 2014 (edited) Thanks. I went to car-part.com but it comes back with"Non-Interchange search using Subaru XT and similar" with no results. No month is asked. you must have done something wrong. do it again. my search returned lots of them, 12 pages of them, including this: 2004 Transmission Subaru Forester 97K, A.T.; W/O TURBO 97,385 $750 what part did you search for, transmission? Edited August 21, 2014 by johnceggleston Link to comment Share on other sites More sharing options...
mohrtek Posted August 22, 2014 Share Posted August 22, 2014 (edited) you must have done something wrong. do it again. my search returned lots of them, 12 pages of them, including this: 2004 Transmission Subaru Forester 97K, A.T.; W/O TURBO 97,385 $750 what part did you search for, transmission? Yes. I believe this happened because I selected USA only. When I removed this it seems to work and I get results, thanks. Still trying to find the transmission code near the starter. I can see the starter but no code on the bell housing. The Turbo radiator blocks my ability to see very well in there. MIght have to remove it just so I can see if there is a code... Edited August 22, 2014 by mohrtek Link to comment Share on other sites More sharing options...
mohrtek Posted August 23, 2014 Share Posted August 23, 2014 I have not looked @ the bell housing near the starter for that code but I will do that ASAP. Will have to figure out where the starter is first . Thanks. OK so the code on the bell housing is TZ1B5LHYAA-1L its throwing the "Shift Solenoid D" CEL code with AT Oil Temp light flashing. I cant get out of 1st gear, off and on. I was told I can replace the valve body, but, when i ordered the 2nd generation from transstar which was supposed to fit the 2004 XT, it did not fit. So does any1 know which transmsisison I have and how to fix this shift issue? Thanks Link to comment Share on other sites More sharing options...
johnceggleston Posted August 24, 2014 Share Posted August 24, 2014 the code on the bell housing is TZ1B5LHYAA that is a forester turbo trans, first used in 03 up through 06. is your car a turbo? 04 forester turbo auto trans part number http://opposedforces.com/parts/forester/us_s11/type_7/automatic_transmission/at_transmission_assembly/ click on usage info to see http://opposedforces.com/parts/info/31000AF600/ Link to comment Share on other sites More sharing options...
mohrtek Posted August 24, 2014 Share Posted August 24, 2014 Yes its a turbo. These codes will help thank you. I next need to find out if the "shift solenoid d" can be replaced or if the whole valve body needs to be replaced altogether. What are the risks of doing the valve body myself. Either way, ill need to identify a reseller who can get me those parts either remanufacired or new. Link to comment Share on other sites More sharing options...
