Removing timing covers without pulling pulley
I used a dremel rotary tool to cut the center cover in half and remove it from around the pulley, and it can still be re attached in 2 parts without removing the pulley.
Or just take off the pulley, there is a hole in the flywheel you can put a punch in to hold the crank still (a bit more difficult on an automatic just jam something in there), and use a breaker bar on the pulley, no need to remove the rad.
Edited by BlackBoot
Mine were badly melted... I removed all the bolts holding the covers to the engine, then broke the remaining cover pieces off. Been running the timing belts "naked" since my rebuild, over a month now of both on and off road, no problems yet.
