arose10 Posted August 2, 2014 Share Posted August 2, 2014 Hi. I recently got a new 2014 Subaru Impreza. I've been wanting to disable the beeping sound that occurs when you're driving without the seatbelt fastened. In the car's manual, it says that this can be taken care of at any authorized service center for Subaru. However, I've visited a couple of Subaru service centers and apparently they're no longer permitted to disable this functionality. I've also inquired about this with a few independent mechanics and have come up empty so far. Any tips would be greatly appreciated!!! Link to comment Share on other sites More sharing options...
heartless Posted August 3, 2014 Share Posted August 3, 2014 easiest way to shut it up is buckle up. Link to comment Share on other sites More sharing options...
Stevo F Posted August 3, 2014 Share Posted August 3, 2014 Likely it would be illegal for any dealer or shop to disconnect it. Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 3, 2014 Share Posted August 3, 2014 Nope, thy just don't want to do it. I know on the older Legacys '05 and newer, you have to turn the key on, click the buckle in and out 20 times within 30 seconds of the key being turned on and then the key has to be turned back off within those 30 seconds. Not sure if it works on the new cars but worth a shot... 1 Link to comment Share on other sites More sharing options...
Bantum Posted August 3, 2014 Share Posted August 3, 2014 You’ll need to get hold of one of these: Found here : http://www.ebay.com/itm/SUBARU-IMPREZA-2008-2014-FACTORY-SERVICE-REPAIR-OEM-WORKSHOP-SHOP-FSM-MANUAL-/191271709224?pt=Motors_Manuals_Literature&hash=item2c88aeaa28&vxp=mtr Then find the relevant section to follow procedure … Cheers, Bantum … Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 3, 2014 Share Posted August 3, 2014 Find the plug for the seatbelt under the seat. Unplug it. The old ones were one wire and this works. Not sure in the new ones but worth a quick look under the seat. Link to comment Share on other sites More sharing options...
brus brother Posted August 4, 2014 Share Posted August 4, 2014 Turn the ignition key to on but DO NOT start the car.Now buckle and unbuckle the drivers seatbeltabout ten or fifteen times QUICKLY and then turn the ignition key tooff. Now turn the key on and start the car as normal. If you weresuccessful as I was on my 05 OB, the chime will chime 5 times when you first turn the key to on and then stop. It will also disable the seatbelt warning for the passenger seat. Link to comment Share on other sites More sharing options...
