86subaru Posted August 3, 2014 Share Posted August 3, 2014 Hello all.no codes .no alt issues.start up hesation just for a few seconds.good battery.new NGK plugs wires.new fuel filter..air filter.sea form thing..what next to look at ? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 3, 2014 Share Posted August 3, 2014 clean the IAC valve? Link to comment Share on other sites More sharing options...
86subaru Posted August 3, 2014 Author Share Posted August 3, 2014 Did that.could it be the coil pack? Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 3, 2014 Share Posted August 3, 2014 Can you describe what you mean by startup hesitation in a bit more detail? Link to comment Share on other sites More sharing options...
86subaru Posted August 3, 2014 Author Share Posted August 3, 2014 Sounds like weak battery .but only last like 2-3 seconds and starts fineq Link to comment Share on other sites More sharing options...
Rooster2 Posted August 4, 2014 Share Posted August 4, 2014 weak starter?? clean battery connections at battery, and at starter. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 4, 2014 Share Posted August 4, 2014 Could be tired/worn out starter motor. Make sure battery connections are tight and clean. Be sure to check connections on the starter as well like Rooster said. If those check out Strip back a little insulation (about an inch) on the battery cables and see if there is heavy corrosion up inside the cables. Link to comment Share on other sites More sharing options...
86subaru Posted August 5, 2014 Author Share Posted August 5, 2014 OK.now brake light comes on a few times.thanks will clean cables on starter Link to comment Share on other sites More sharing options...
