CODYZOOMZOOM Posted August 4, 2014 Share Posted August 4, 2014 I can't figure it out its a ea82 fi any ideas Link to comment Share on other sites More sharing options...
superpoo93 Posted August 4, 2014 Share Posted August 4, 2014 Uh? Are you saying, how do you tell if it's a EA82?? Link to comment Share on other sites More sharing options...
MilesFox Posted August 5, 2014 Share Posted August 5, 2014 Probably the IAC is stuck open or has a loose hose. Link to comment Share on other sites More sharing options...
CODYZOOMZOOM Posted August 5, 2014 Author Share Posted August 5, 2014 No it is a ea82 and it won't idle lower than 1500rpms and OK I'll change that I have another Link to comment Share on other sites More sharing options...
ellevehc Posted August 14, 2014 Share Posted August 14, 2014 You close the butterflies in the carb. That is where it would normally get air and how you control idle. When they are fully closed and you're still idling, you are getting the air from somewhere else. It's a vacuum leak. Probably a hose. Spray certain areas with carb cleaner until the idle fluctuates. Wherever it fluctuates after spraying is where your leak is. Link to comment Share on other sites More sharing options...
Goldenhands57 Posted August 14, 2014 Share Posted August 14, 2014 Any codes flashing on the ECU? Is the idle steady at high RPM or wandering/sputtering/cutting in and out? IAC is the first suspect on these engines, they get stuck...gotta keep them clean to work correctly. Vacuum leaks also as mentioned. MAF sensors also do very funky things to the injection rate on both SPFI or MPFI, and the old school Subaru MAF is not the best system out there for durability. You can try cleaning the hot wire but be very careful not to damage them. Aerosol cleaner from the big box auto parts store will work; for a while. If that resolves the issue be looking to buy a known good MAF cause the one you have in there now is on borrowed time. Link to comment Share on other sites More sharing options...
Gloyale Posted August 14, 2014 Share Posted August 14, 2014 (edited) Okay.....>We need to determine if this car is Carbed or SPFI....... Being an 87 it could be either.........2wds and 4wd CALI spec cars will be SPFI, 49 state 4wds will be Carbed. First thing to ckeck with either is the throttle cable....is it too tight??? If not....then again Carb vs. SPFI could be different things. Carbed: IF it's not the linkage.....it's likely a vac leak......or an air bleed leak(slight difference) the air bleeds are the slightly larger tubes that come from the top of the carb to the valve on the pass side of the intake........This valve is supposed to at idle nearly close the main secondary air bleeds, and to open the Primary Slow air bleed (these are the ports that meter enrichment)........If those hoses, or the vavle are missing......or if the small "orifice" pellets have been taken out of the tubes......the car will pull too much air through the bleed.......causing a high, but lean idle. SPFI: IAC hose loose, weak, crakced, or the IAC stuck open.......check by pinching the IAC tube closed and if the idle drops that's the problem. Idle can be adjusted using screw behind IAC passenger side of the TB Edited August 14, 2014 by Gloyale Link to comment Share on other sites More sharing options...
