tdwhite Posted August 10, 2014 Share Posted August 10, 2014 Im working on replacing the bushings on my 05 Outback. At first I had trouble removing the control arm from the ball joint (tried both removing the bolt from the pinch knuckle then a beating to the control arm and removing the cotter pin and trying the same beating with a hammer) but I had no luck. Then decided I might beable to finish the job by leaving it in. So I disconnected the control arm from everywhere but the ball joint and was able to remove the old torn busing and the metal ring around it. Now I am having trouble pushing in the new bushing. Does anyone have any ideas on getting the ball joint out? Im going to take both arms to a shop to get them pushed in. I need to have this done by thursday I will be driving back to college. Link to comment Share on other sites More sharing options...
john in KY Posted August 10, 2014 Share Posted August 10, 2014 (edited) Use a pickle fork and buy new ball joints because the pickle fork will damage the original ball joints. http://www.ehow.com/video_2327952_use-upper-lower-ball-joints.html Edited August 10, 2014 by john in KY Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 11, 2014 Share Posted August 11, 2014 I use a 3lb hammer and strike the at side of the control arm where the ball joint stud goes through. 3-4 solid hits usually pops it loose. It also helps to have a large prybar to help pull the control arm down while you swing the hammer. Since you have the bushings knocked out of the arm you'll have put it back in place and slide the bolts through to hold it. The steel sleeve bushings can be a pain to replace without a press, but a vice usually works to push the new ones in. Link to comment Share on other sites More sharing options...
14D Posted August 11, 2014 Share Posted August 11, 2014 I've used a 2/3 arm puller on stuck ones before. Something like this would work even better though. http://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html Link to comment Share on other sites More sharing options...
