1996 subaru legacy outback strut swap with only front spacers?
I was wondering can i put strut spacers in just the front of my subaru legacy wagon? i put outback struts on it. but when im going over small bumps the nose wants to go into the ground more and more as im driving faster? can i put spacer in the front to minimize this problem?
if the car is nose diving you have other suspension issues and a spacer will not fix that.
I have all new forester struts, springs & tophats on my 95 Lego - body movement going over bumps is almost nonexistant.
were the struts you put in new or used? if used, I would bet they are worn out
how about the springs? springs can & do wear out...especially if worn struts are left in for extended periods
