palfer Posted August 17, 2014 Share Posted August 17, 2014 Continuing to rehab my new 97 Impreza Outback (159K miles) and was trying to get behind the crank sprocket to replace the front seal and re-seal the oil pump. I get the sprocket to move forward but it keeps snagging right at the end of the shaft. I move it far enough forward to see the seal behind it is brown which I believe indicates its been replaced as the cam seals I removed are black. Unfortunately in trying to pry off the sprocket I snapped two of the four tabs and still unable to remove it. My question is by snapping the tabs am I committed to removing/replacing the sprocket or can I leave it on cross my fingers and hope the seal never leaks. If I have to get it off, any ideas how? I'm not seeing anything obvious that would cause it to hang up. Thanks Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 18, 2014 Share Posted August 18, 2014 If you broke the tabs you need to remove it. The crank position sensor has to count those tabs to figure ignition and fuel injection timing. If any are missing it loses the sequence and you'll get a no-start condition. The ones that I've done take some wiggling and a little shot of PB but usually slide off without a puller. Check the end of the crank for burrs or nicks. Also if the key slot is still on make sure it isn't chewed up. If you find any rough spots smooth them out with some sand paper or emory cloth. Link to comment Share on other sites More sharing options...
palfer Posted August 18, 2014 Author Share Posted August 18, 2014 Thanks. I figured as much. I was able to pull the key out with a pair of vise grips so it now spins freely on the shaft but still snagging up. Lightly filed the edge of the shaft assuming it gummed up or slightly out of round. Still no luck. Will keep at it. Link to comment Share on other sites More sharing options...
palfer Posted August 18, 2014 Author Share Posted August 18, 2014 Good news. got it off. Do you guys recommend re-sealing the oil pump on the 2.2L? I've done it on 2.5L, not sure the 2.2 is prone to the same issue. Link to comment Share on other sites More sharing options...
Olnick Posted August 18, 2014 Share Posted August 18, 2014 By all means reseal the 2.2's oil pump while you're in there--backing plate screws sometimes loosen. Might want to replace cam and crank seals too, and the cam o-ring in the driver's side front. Link to comment Share on other sites More sharing options...
