EA82 rear axle stub bolts stuck!
So I've been giving those bolts a good whack with a hammer and a lot of pb blaster but they wanna stay right where there at. I've been using a 8mm socket but I'm worried I may strip the heads so I'm gonna grab an e10 torx if it doesn't wanna budge soon. Any tips on getting these things out without destroying my stubs? Thanks guys!
I'm not sure what bolts are you talking about. Removing the rear axle takes punching out the spring pins, the lock ring, axle nut and you gotta pound the stub out of the bearing...but there aren't any bolts in the stub right?
