Goatboy Posted May 12, 2004 Share Posted May 12, 2004 According to any repair manuals I have seen they say you need to pull the engine and the transmission together. Now c'mon I know thats not true is it? Anyone have some tips for a fast and easy, relative of course, auto tranny pull and install. just pulling one and putting in another one. Thanks! GoatBoy Link to comment Share on other sites More sharing options...
calebz Posted May 12, 2004 Share Posted May 12, 2004 Funny.. All of my manuals specifically say to NOT pull the engine and tranny together. Get a tranny jack, unbolt stuff, remove tranny.. Installation is the reverse procedure Link to comment Share on other sites More sharing options...
mr.radon Posted May 12, 2004 Share Posted May 12, 2004 I made a bar with the holes spaced just right to put in place of the dog bone. You bolt it in and it angles the tranny down just right to allow a tranny jack to grab it nad back it right outa there. I can't see how you could ge them out bolted together. I just did a auto to manual conversion, if this is what you're doing I got some advice. Link to comment Share on other sites More sharing options...
Goatboy Posted May 12, 2004 Author Share Posted May 12, 2004 Nope. Not doing a manual swap. Just one auto for another. Link to comment Share on other sites More sharing options...
Goatboy Posted May 13, 2004 Author Share Posted May 13, 2004 Anyone got a step by step or best practices or just some plain old shade tree tips for me? GoatBoy Link to comment Share on other sites More sharing options...
MilesFox Posted May 13, 2004 Share Posted May 13, 2004 unbolt the bellhounsing. take off the starter and pitch bar. remover the rubber cooling lines from the tranny end. disconnect the speedo cable and electricals. unboly the torque converter bolts, four each 12mm thru the timing window. you can take off the pitch bar mount to use a socket, or just use a box end. i use a prybar top separate the torque converter from the flex plate, so that it stays with the tranny and prevents a mess. get under the car. dranin the ATF. remove the y pipe for access. unbolt the shifter nut from the shifter itself. leave it connected to the tranny end unbolt the tranny crossmember bolts. lower the tranny down with a jack. if you jack up the SIDE of the car iy will give you more room to work. Link to comment Share on other sites More sharing options...
