virginiaham Posted August 21, 2014 Share Posted August 21, 2014 so the other day when i went to park my 97 Legacy wagon, and put all the windows up, the Right Rear window would not go up straight. I've taken the door panel off to investigate what broke, and i found that one of the little plastic bushings where the window regulator arm snaps into and slides in the rail bolted to the bottom of the glass had broken in half, and so only one of the two regulator arms is actually attached to the glass. my question is, is this bushing available separately anywhere, or am i forced to just replace the entire regulator? a regulator is not too expensive, but two little plastic bushings have to be even cheaper, right? Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 21, 2014 Share Posted August 21, 2014 You might be able to get them from Subaru. Try looking in the parts diagrams at Opposedforces.com. Link to comment Share on other sites More sharing options...
Rooster2 Posted August 21, 2014 Share Posted August 21, 2014 On 8/21/2014 at 1:41 PM, Fairtax4me said: You might be able to get them from Subaru. Try looking in the parts diagrams at Opposedforces.com. If not from Subaru, then try a wrecking yard. Link to comment Share on other sites More sharing options...
upnorthguy Posted August 21, 2014 Share Posted August 21, 2014 A window regulator is $10.48 at www.pickapartva.com just south of Quantico (plus $2 to get into the yard). Link to comment Share on other sites More sharing options...
