EA82 intake gaskets...im a dork
Hi all,
So in my continued attempt to revive my 91 loyale wagon, i removed the intake to replace the gaskets and change tbi gaskets and parts. I forgot to drain coolant. As i removed the intake, coolant leaked out. I then drained some out of the radiator. After removing intake, i noticed the driver side intake to the head was filled with coolant. Pfffff. I sucked it out, cant see anymore in there. I guess i should have pulled the drain plugs to block? Question is hopefully all i will get is some white smoke when i fire it up?
Live and learn i guess. Im a newbdork :)
