Cmosfet Posted August 23, 2014 Share Posted August 23, 2014 Hi all, So in my continued attempt to revive my 91 loyale wagon, i removed the intake to replace the gaskets and change tbi gaskets and parts. I forgot to drain coolant. As i removed the intake, coolant leaked out. I then drained some out of the radiator. After removing intake, i noticed the driver side intake to the head was filled with coolant. Pfffff. I sucked it out, cant see anymore in there. I guess i should have pulled the drain plugs to block? Question is hopefully all i will get is some white smoke when i fire it up? Live and learn i guess. Im a newbdork Link to comment Share on other sites More sharing options...
Idasho Posted August 23, 2014 Share Posted August 23, 2014 Pull the spark plugs, crank engine over. Replace plugs, drive! Link to comment Share on other sites More sharing options...
Cmosfet Posted August 23, 2014 Author Share Posted August 23, 2014 Ah sweet...thank you. Feel better now. Link to comment Share on other sites More sharing options...
jono Posted August 24, 2014 Share Posted August 24, 2014 not the only dork to have done that fine stunt ! Link to comment Share on other sites More sharing options...
TomRhere Posted August 24, 2014 Share Posted August 24, 2014 guilty Link to comment Share on other sites More sharing options...
