opus Posted August 25, 2014 Share Posted August 25, 2014 Can anything be done to clean up, remove things from an EA82 turbo engine compartment. My Brat and other GL engines are naked now and I'd like the same for the GL-10 turbo. What can be removed without negative effects? Link to comment Share on other sites More sharing options...
scoobiedubie Posted August 25, 2014 Share Posted August 25, 2014 It is a pretty simple engine. You will find that if you remove anything, the engine won't run well. You can upgrade to a double core radiator and Gen 3 cylinder heads. Link to comment Share on other sites More sharing options...
opus Posted August 25, 2014 Author Share Posted August 25, 2014 I dont want to do any engine mods really. Its far from simple if it wont run with all the junk attached to it. Anyways.... Link to comment Share on other sites More sharing options...
