My 98 gt seems like its running on 3 cylinders. No codes present, I checked the timing and its good. It had an o2 censor code so I replaced it but no change in his it runs. I'm wondering if a bad head gasket would not throw a code.
Thanks
Dp213
move the wires around if they'll reach and see if the misfire follows the wire. Some folks have found arcing by water-misting the coil and wires of their idling engine at night. If the easy tests don't find anything, might need a compression/leakdown test or drop the exhaust manis and see if a valve guide has shifted?
Edited by 1 Lucky Texan
If it has no distrubutor (which it shouldnt) it has coil packs, which are waste spark systems. In a waste spark system the coils will fire in pairs, hence 1-2, 3-4. It gets a little confusing, ignition order (firing) is as you said.
Firing order is 1-3-2-4
Plugs are fired in pairs 1&2, 3&4. The coil fires both plugs at the same time. It's a waste spark system. One plug fires on tdc compression, the other on tdc exhaust stroke.
Cylinders 1&3 are the right half of the block so if those are misfiring the problem could be jumped timing.
