jmoss5723 Posted August 28, 2014 Share Posted August 28, 2014 The sprayer for the windshield washer in the Ski Wagon (83 GL) is incredibly weak. The driver's side (first in line in the tubing) practically dribbles out, and the passenger side doesn't get enough pressure to put out any washer fluid at all. I can hear the little pump pumping and see the fluid moving through the lines, it is just really wimpy. Do I just need to replace the little pump/motor? Is there something else I should check first? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 28, 2014 Share Posted August 28, 2014 Yes... ... the passenger side doesn't get enough pressure to put out any washer fluid at all... ...try to Clean the Clogged nozzle first. Kind Regards. Link to comment Share on other sites More sharing options...
jono Posted August 28, 2014 Share Posted August 28, 2014 with a Fine needle from the Outside of nozzle jet 1 Link to comment Share on other sites More sharing options...
l75eya Posted August 29, 2014 Share Posted August 29, 2014 Do you get good pressure out of the hose itself, before the nozzles. Link to comment Share on other sites More sharing options...
skishop69 Posted August 29, 2014 Share Posted August 29, 2014 Sounds liked it's plugged. Either the pump screen, mail line or nozzles. We used compressed air at work for the lines and nozzles. Link to comment Share on other sites More sharing options...
jmoss5723 Posted August 29, 2014 Author Share Posted August 29, 2014 Well now I feel dumb. I can't believe it never occurred to me that the nozzles would be clogged. Duh! Thanks guys. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 29, 2014 Share Posted August 29, 2014 ...Thanks guys. You're Welcome! Don't forget to let us know if you solve the issue. Kind Regards. Link to comment Share on other sites More sharing options...
