Mykeys Toy Posted August 31, 2014 Share Posted August 31, 2014 I have had it for a long while and finally adjusted the valves this weekend. One intake #3 was a little loose and one Exhaust #4 was quite tight. Adjusted and double checked. Put her all back together and still have valve noise from what sounds like number 4. Any ideas or will a short drive maybe work it out? Dunno what else to do short of running seafoam or something. Mike Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 3, 2014 Author Share Posted September 3, 2014 Seafoam it is.. This weekend. If no joy then I will pop off the rocker assembly and check the pushrods and hope that I didn't bend one. Can I use a straight one from another engine if mine turns up bunk? Link to comment Share on other sites More sharing options...
