redloyale Posted September 3, 2014 Share Posted September 3, 2014 I'm putting a 4" lift on my loyale. It has a three speed auto for now. If I put 235/75r15 mud terrain on it , will it be driveable as far as power goes. I'm hoping someone has first hand experience with this combo. Thank you for the help. Link to comment Share on other sites More sharing options...
Prwa101 Posted September 3, 2014 Share Posted September 3, 2014 Who's 4" lift are you putting on? I fit 235/75/15 with minimal trimming, if any at all. https://m.facebook.com/profile.php?v=timeline&id=1458812977704910&_rdr Happy valley is a good area! I'm in sandy! We need to get that thing lifted so we can wheel!! Prwa Link to comment Share on other sites More sharing options...
redloyale Posted September 3, 2014 Author Share Posted September 3, 2014 Sjr I'm not asking about clearance. I'm asking about power. With three speed auto. Will it be able to pull hills on hwy? Link to comment Share on other sites More sharing options...
Prwa101 Posted September 3, 2014 Share Posted September 3, 2014 With the stock ea82 and an auto and 235/75/15... It'll role down hill pretty good. Haha. It'll be slow though. Prwa Link to comment Share on other sites More sharing options...
redloyale Posted September 4, 2014 Author Share Posted September 4, 2014 Its already slow with stock size tires. we want to be able to go up and play in the snow. Just want to know if i'll be able to pull the road up hood with out holding up all the traffic or smoking the transmission. we'll get together and go to the mountain as soon as I get it put together. Link to comment Share on other sites More sharing options...
Prwa101 Posted September 4, 2014 Share Posted September 4, 2014 Yeah it will prolly chug along slowly. I've heard those trannys arnt terribly reliable though. Might wanna think about doing a 5 speed/DR swap in the near future. And even then the ea82's just arnt strong enough. Nick's build on here runs 235/75/15's doesn't do terribly but it's still 0-60 in 15min haha. Link to comment Share on other sites More sharing options...
redloyale Posted September 4, 2014 Author Share Posted September 4, 2014 Is his 3 speed? where do I find his build? Link to comment Share on other sites More sharing options...
DaveT Posted September 4, 2014 Share Posted September 4, 2014 I run nothing but EA82 #AT wagons. The last thing I would do is put tires with bigger diameter on them. Link to comment Share on other sites More sharing options...
redloyale Posted September 4, 2014 Author Share Posted September 4, 2014 why do you say this? Link to comment Share on other sites More sharing options...
Vegablade Posted September 5, 2014 Share Posted September 5, 2014 On 9/4/2014 at 2:44 AM, redloyale said: why do you say this? Automatic transmissions in these are pretty weak. You will have a hard time pulling hills. Even with a Weber and 5-Speed i have a hard time with anything other then flat ground with 235s, even then I just keep it in 4th. Link to comment Share on other sites More sharing options...
DaveT Posted September 5, 2014 Share Posted September 5, 2014 putting bigger diameter tires - the outside tread diameter, not the rim - is like putting in a higher gear. Except all your gears are higher. You get more speed on the flat for the same engine RPM, but in these cars, the engine is just barely enough power as it is... Link to comment Share on other sites More sharing options...
dannycisneros Posted September 5, 2014 Share Posted September 5, 2014 I also have a 3AT but I'm only doing a 2 inch lift. Tryin to buy a set of wheels and going with something like 195/75 or 27s. Link to comment Share on other sites More sharing options...
Vegablade Posted September 5, 2014 Share Posted September 5, 2014 On 9/5/2014 at 5:22 AM, dannycisneros said: I also have a 3AT but I'm only doing a 2 inch lift. Tryin to buy a set of wheels and going with something like 195/75 or 27s. I had 27s before my 29s. It was ok on the flat but definitely had to downshift for the hills in my 5-speed, even with a wever. You may have a hard time with the tall gears in an automatic even with 27s or 26s. Link to comment Share on other sites More sharing options...
